How to remove a sway bar link on a 2014 JKU Sport?
jeepabout
Hi,
I bought new links and I went to replace the old ones but I can only see one nut on the top connection for the link.
I know stupid question. ;-)
Thank you
jeepabout
Your partly correct, you do need a hex key
So I peeled back the rubber cover and did not find ant opening, then I looked in the end of the bolt on the side where the nut is, that has a hex opening.
Thanks again for the reply.
:thumb:
-AINOKEA-
:thumb:
Wtf? Don’t think that’s how you do it. If it works, great.
Put a wrench on the left side hex nut on the left side of the sway bar in this pic, then use a socket or another wrench to loosen the nut on the right side of the sway bar.
desertrunner
This was the place to put a wrench on that I was trying to say on the bushing side... But it's not unheard of to put something like an Allen wrench in the stud of a ball joint to tighten the nut just like you did with the sway bar link but I think you made it harder than you needed haha
toyotire
the OP's swaybar links are not stock links they are Teraflex. They do not have a place for a standard wrench like OEM.
jeepabout
There is no nut on the inside of this model, lucky me.
Thanks for the replies :) 20190514_125052.jpg
Sent from my SM-G935T using Tapatalk
