Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Low range and won't go!
  1. #1
    Knows a Thing or Two bhaner's Avatar
    Join Date
    Jul 2017
    Location
    Wickersham, Wa
    Posts
    552
    I will come up against an obstacle and the engine will just bog and the rpm's won't come up. Esc shows off. Holding the auto in 1st.
    Is there a trick to get it to go?
    Byron Haner - Wickersham, Wa
    2016 JKUR HR
    Evo Offroad DTD w/Evo Lever
    Dynatrac Elite ProRock XD60/80
    40" Procomp MT, 17" B.A.D. Wheels
    My Build Thread
  2. #2
    Nothing but a Thing jorgelrod's Avatar
    Join Date
    Sep 2013
    Location
    Jacksonville, FL
    Posts
    1,979
    On the floor there should be a two pedals, the one on the right side, you press on it and it goes...
  3. #3
    Join Date
    Jul 2017
    Location
    Wickersham, Wa
    Posts
    552
    Quote Originally Posted by jorgelrod View Post
    Lol! That is the problem! I can floor it and it won't go!
    2016 JKUR HR
    My Build Thread
  4. #4
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    3,648
    On my Jeep, sometimes it likes to pop out of 4 lo, even though it appears to be in, with the lever in the right place and ESC light OFF. When I shift it into 4 lo I use one hand to firmly shift into 4 lo and use other hand to put it back to drive while holding pressure on the t-case lever
  5. #5
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    4,268
    You need to be in 4 low. I have what you describe if I try to wheel in 4 high over moderately large obstacles.
  6. #6
    Nothing but a Thing Stotch's Avatar
    Join Date
    Jan 2016
    Location
    SW MO
    Posts
    1,460
    What gears are you running?
  7. #7
    Join Date
    Jul 2017
    Location
    Wickersham, Wa
    Posts
    552
    Quote Originally Posted by fiend View Post
    It's in low. I am sure of that.
    It seems like an electronic issue. Like torque management. Feels like the traction control is on and it is cutting the power.
    If I let off and roll in really slow sometimes it will go fine. But I can also floor it and it will do nothing but load the engine. RPM's won't go much over an idle.
    2016 JKUR HR
    My Build Thread
  8. #8
    Join Date
    Jul 2017
    Location
    Wickersham, Wa
    Posts
    552
    Quote Originally Posted by Stotch View Post
    5.38 and 40's.
    2016 JKUR HR
    My Build Thread
  9. #9
    Join Date
    Jul 2017
    Location
    Wickersham, Wa
    Posts
    552
    Quote Originally Posted by VeruGE*144 View Post
    Yep. I will hold mine in low when shifting it and go reverse to drive to make sure it is locked in all the way.
    It's not coming out of gear. Something is just not letting the engine apply power.
    2016 JKUR HR
    My Build Thread
  10. #10
    Addict Brute's Avatar
    Join Date
    Nov 2015
    Location
    Mainland
    Posts
    8,765
    Quote Originally Posted by bhaner View Post
    Front hubs not locked?
Similar Threads
  1. STT Pro 37s Load Range D or E
    By JoeB-JKURX in forum Wheels & Tires
    Last Post: 11-26-2018, 02:33 PM
  2. Long Range Precision
    By Omnifox in forum The 8th Slot
    Last Post: 03-04-2018, 08:01 PM
  3. Need More Steering Box Range
    By fpat99 in forum Jeep JK Wrangler
    Last Post: 04-05-2016, 06:46 PM
  4. JKUR key fob range
    By Rccrwlr in forum Jeep JK Wrangler
    Last Post: 06-17-2015, 04:26 AM
  5. 513s RPM range
    By Jeeper714 in forum Jeep JK Wrangler
    Last Post: 08-23-2014, 03:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
