Results 1 to 5 of 5
Thread: 2014 overheating issues
  1. #1
    Fresh Catch
    May 2019
    orlando
    1
    Hi All,
    First post here so go easy on me.
    A couple of days ago my 3.6l 2014 JK started overheating badly on the way home. Once I got it home It gave me a check engine code:
    P0117 - Engine coolant temperature sensor 1 circuit low input.
    I got in the engine bay, and did some digging. Both the upper and lower coolant hoses were emtpy, and cold, the fan was always on while the engine was running, no visible leaks in the coolant system.
    This told me it was a thermostat, or water pump issue. I replaced both of those to no success.
    I then replaced the radiator, to no success.
    After replacing those 3 components, I'm pretty stumped on what to do. I don't think its the temperature sensor as the engine is almost certainly running hot (fan constantly on, burning smell from the engine bay), and I don't think there is a leak anywhere.
    Anyone on here got any bright ideas?
    Thanks a lot!
  2. #2
    Nothing but a Thing RESURECTIONJK's Avatar
    Oct 2016
    SALT LAKE CITY, UTAH
    1,949
    I’d say a possible blockage in the heater core is something to consider. I’m sure others will chime in as well. In the mean time head over to the wave section and say hi and introduce yourself. Lots of helpful people here.
  3. #3
    Caught the Bug Zeus's Avatar
    Nov 2016
    South Africa
    82
    Did you bleed the system properly after the replacements parts?
    2013 Jeep Wrangler JK Rubicon
    2.5" AEV, Andvanced Offroad front and rear Bumpers, Smittybilt XO2 winch, AEV Snorkel
    33" Cooper STT Pro's
  4. #4
    Hooked G-mansjk's Avatar
    May 2017
    Ca
    119
    If your cooling system was empty and there were no visible leaks you need to check your head gaskets. Do you have more visible fluid coming out of the exhaust than normal? Is your oil over full and milky? The leak can be easily tracked down with hvac uv dye you can find at any part store and a cooling system pressure tester. Pour the dye in the coolant run it to mix then pressurize the system. Often you can hear the hissing where it's leaking if not throw the uv light in the bay and look for leaks.
    Sent from my SM-G975U using WAYALIFE mobile app
  5. #5
    May 2017
    Ca
    119
    Side note don't pressurize the system more than what's noted on your cap. The 3.6l if I remember correctly is 15psi which is pretty standard so don't go over 15psi with the tester or you can blow hoses or create new leaks to fix Haha.
Similar Threads
  1. 2013 JK No Heat issues / Coolant Issues
    By matt87951 in forum Jeep JK Wrangler
    Last Post: 06-27-2019, 08:46 PM
  2. New issues with 2014 Sahara
    By kellyk in forum Jeep JK Wrangler
    Last Post: 01-21-2019, 02:56 AM
  3. New overheating issues after submersion
    By -AINOKEA- in forum Jeep JK Wrangler
    Last Post: 09-14-2018, 11:46 PM
  4. Overheating issues
    By kawimoto in forum Jeep JK Wrangler
    Last Post: 07-14-2017, 12:41 AM
  5. 2014 jku alignment issues
    By shortyokc in forum Jeep JK Wrangler
    Last Post: 09-28-2014, 06:11 PM
Tags for this Thread
