JL JOURNAL : Synergy Snap-Lock Bump Stop Spacer System for Jeep JL / JK Wrangler
In spite of what a lot of people seem to think, the whole point of installing bump stop extensions isn’t necessarily to help prevent your tires from rubbing your fenders at a full flex. I mean, sure, they’ll do that too but that’s not the main reason why you should want them. The main reason is to help prevent things like your shocks from bottoming out and maybe more importantly, to help prevent the over compression of your coils. As in, compressing them to the point where they no longer return to their original height. It’s for this reason that most lift kits come with bump stop extensions that are about the same height as the lift you’re installing.
Now, where things get tricky is when you want to upgrade your coils to something a bit taller but without having to install a whole new lift kit. Because most lift coils tend to yield way more lift than is advertised, this can make it hard to know just how much of a bump stop extension you really need. Of course, if you've just installed a bigger set of tires and would like to mitigate the rubbing you're now getting from them, a taller set of bump stop extension can be helpful there as well. Fortunately, Synergy came up with their all new Snap-Lock Bump Stop Spacer System.
PLEASE SUBSCRIBE
If you enjoyed this video, Cindy and I would be grateful if you could please SUBSCRIBE to our YouTube channel!
https://www.youtube.com/wayalife?sub_confirmation=1
Synergy Jeep JK/JL Snap-Lock Bump Stop Spacer System
18+ Jeep Wrangler JL/JLU
07-18 Jeep Wrangler JK/JKU
Features:
• Molded and machined from fiber reinforced composite
• Can be used on the front or rear of the vehicle
• Bump stop spacing can be changed on the vehicle without removal of any hardware
• Bump stop spacers bolt on to the axle and provide 2, 3, or 4 inches of extra limitation for larger tires or shocks
• 100 percent bolt on components assures an easy, trouble free installation with the use of basic hand tools
Bear_JT
Thank you for showing these Eddie and Cindy. I’ve actually recently been looking at getting these I like that you can add or subtract as needed. Your video has me hooked now.
Ddays
Ok, now that's pretty slick! I'm gonna have to order these when I decide on my lift later this Summer. :thumb:
So many people overlook bump stops and even more so, rarely take the time to fine tune everything so they are getting exactly what they need out of their suspension. Cool that synergy makes it easier to figure out and adjust.
wjtstudios
They make a lot of sense to get your Jeep dialed in. Is there a version for the rear stops too?
2015 JKUR AEV JK350
1985 Jeep Scrambler
LOL - glad we could be of help :)
Awesome :cool:
Those are pretty clever might have to get me a set. Can you put on rear as well?
So, these are supposed to be universal and you should be able to install them on the rear as well. On the rear, you're supposed to drill through the flat bump stop plate on the axle. The only problem is that if you drilled right through the center of the plate, you'd be drilling right into the axle tube. Of course, the rubber jounce doesn't really strike dead center so I suppose it would just take some figuring out where to put them. I'm not gonna lie, I wasn't really feeling it and really, addressing the rear isn't nearly as tough as the front being that the bump stops are outside of the coil. You can pretty much install these or anything without having to remove anything on your Jeep.
Very cool. Somehow I didn’t know these existed. I might have to snatch me up a set
LOL!! Glad we were able to show you something new :)
Honestly, I just think that most people don't know what to look for or know that things need to be dialed in. And then, they later complain about how their lift no longer sits as tall as it used to and wonder why.
What a great idea.
I think so :)
Pretty cool, but why didn't I think of it? Lol.
LOL!! I know, right? :crazyeyes:
You're up to something.... :hmm:
:cheesy: We're always up to something :D
That’s a great idea!
I think so too :)
Good stuff, very useful. Thanks for sharing!
Awesome! Glad we could share this with you :)
According to the Synergy site, they can be used front or rear.
Yup. :yup:
Those are really cool! Thanks for the video!
You bet :)
wjtstudios
I think so :)
That makes sense, and there is a bunch more access there.
Thanks for the insight
2015 JKUR AEV JK350
1985 Jeep Scrambler
