Results 1 to 7 of 7
Thread: Out of round or out of balance?
  1. #1
    Been Around the Block sm31's Avatar
    Join Date
    Nov 2012
    Location
    Eagle River, AK
    Posts
    302
    Just rotated my tires (5 wheel rotation) for the first time since purchasing, and as luck would have it... the newly rotated "spare" looks like it may have a balancing issue. But I'm wondering... is there a way to tell whether a tire/wheel is out of round rather than out of balance? If it is out of round, I'm afraid it might be too slight to see just from giving the unweighted wheel a spin... but there is just enough wobble of some sort to give annoying feedback through the steering wheel. Thinking of loosening and re-torquing the lug nuts in case that may help but it's a long shot.
    Since they're beadlocks, is there anything else I can try at home? Guess I could re-mount the tire (once I confirm it's the former spare) but I'm not sure that will have any effect.
    Thanks!
  2. #2
    Join Date
    Feb 2017
    Location
    US
    Posts
    50
    It think it's more likely the tire needs to be balanced than it be out of round. Try balancing and see if the problem is corrected
    Sent from my SM-N960U using Tapatalk
  3. #3
    Hooked Whitarmy's Avatar
    Join Date
    Aug 2017
    Location
    Texas
    Posts
    135
    I got the same thing going on. Iíve been to discount tire multiple times to try and rebalance the one Iím having issues with. I finally gave up yesterday and Iím just running it on the back since I hardly notice it there. I assume itís got a small flat spot that I canít see since they swear itís balanced. Maybe it will wear to round again? If not, time to try out some STT Pros
  4. #4
    Fresh Catch
    Join Date
    Jul 2019
    Location
    California
    Posts
    14
    by putting a tireless wheel on a balancer and giving it a spin you should be able to see even the slightest out of round/bend. if its so minor you cant see it, then it should affect the ride. the tire could be out of round but that's impossible to tell by sight, as far as i know. typically if the whole combo is out of round but the wheel checks out then its determined to be the tire (have dealt with this more than a few times).
    are your wheels hub centric? if not, do you have hub centering rings? that can cause vibration and feel like something is out of round. or, like you said, could be a flat spot if the vehicle has been sitting for a long time.
  5. #5
    Old Timer sipafz's Avatar
    Join Date
    Mar 2015
    Location
    Saukville, Wisconsin
    Posts
    2,591
    In the case of tires, out of balance is caused by an out of round condition. Itís that simple!
  6. #6
    Join Date
    May 2015
    Location
    Ga
    Posts
    93
    Iím having the same problem with new sst pros. The guy balancing the tires told me that he loves the sst pro but they are hard to balance. I also think my bead lock rings have something to do with mine. Iím gonna break mine down and reinstall the ring and see if it makes a difference
  7. #7
    Knows a Thing or Two trailraider's Avatar
    Join Date
    Jan 2015
    Location
    calgary
    Posts
    797
    Was the spare tire balanced when you originally bought it? have it road force balanced.
    Jeep- Adult version of lego
Similar Threads
  1. Balance 35s
    By JoseRubicon in forum Jeep JK Wrangler
    Last Post: 04-28-2017, 02:52 AM
  2. Tire balance
    By Mdrobb in forum Wheels & Tires
    Last Post: 09-12-2015, 04:39 PM
  3. Balance and Rotate
    By BlackHat in forum Discount Tire
    Last Post: 05-02-2015, 04:26 PM
  4. New JE Reel out of balance?
    By Mdrnizd in forum Jeep JK Wrangler
    Last Post: 04-29-2014, 03:00 AM
  5. 37's balance issues
    By 4Low in forum Jeep JK Wrangler
    Last Post: 04-27-2014, 08:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
