Results 1 to 6 of 6
Thread: Rubicon E-swaybar disconnect
  1. #1
    Hooked Kenthejeepguy's Avatar
    May 2017
    Tuolumne, CA
    156
    Like so many others, the e-disconnect swaybar had water in it and is toast. (happened twice before and was replaced under warranty, but now itís on 𝗺𝘆 pocketbook.) 2011 JKRU BTW. 56k miles. I was looking at the EVO air-powered disconnect, but then I tested my old one. The motor still works, and reverses when the leads are changed. Has anyone hardwired a switch to theirs? A momentary DPDT switch ought to work. Crazy idea?
  2. #2
    Addict BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    6,366
    Quote Originally Posted by Kenthejeepguy View Post
    Can't be momentary. Need constant power to hold the bar unlocked... It springs back to locked once power is removed.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  3. #3
    Been Around the Block uberc4's Avatar
    Aug 2015
    Arizona
    479
    I would go with the Evo manual disconnect. By far one of the best decisions I have made. Granted you do need to remember to connect it back when you get on pavement otherwise it will be fun.
  4. #4
    Living the WAYALIFE Ddays's Avatar
    Aug 2015
    Darlington, Pa
    11,662
    Quote Originally Posted by uberc4 View Post
    Haha ^^ fun is right.
    I second the manual. If I had the opportunity to disconnect more than I do I'd consider the air version but the manual is stupid easy.
    https://wayalife.com/showthread.php/...build-of-Gruff
    Gruff 2014 JKU Moneypit
    Badger 2019 JLUR waiting for scraps
  5. #5
    May 2017
    Tuolumne, CA
    156
    Quote Originally Posted by Ddays View Post
    I live close to lot of trails and use my disconnect frequently. Donít think it requires constant power, as the motor turns a screw, then turns off. If direct wiring doesnít work then I will use an air powered disconnect so I donít have to get out in the mud and dirt if needed.
    Besides, the manual disconnect is about $100, and I can get an air power disconnect for about $200. For a hundred bucks I think itís worth the convenience.
    IMO anyway
  6. #6
    Knows a Thing or Two Samuelh3's Avatar
    Apr 2017
    Southern California
    832
    I'm starting to have the same issue. Very annoying. I'm gonna drop it off at the dealer when I get back from my trip in Tahoe.
Similar Threads
  1. EVO NoLimits Manual Rubicon Swaybar Disconnect
    By 07rub in forum Jeep JK Wrangler
    Last Post: 04-19-2018, 08:49 PM
  2. 2013 Rubicon swaybar disconnect issues?
    By bowtech50 in forum Jeep JK Wrangler
    Last Post: 10-18-2015, 10:49 PM
  3. Rubicon Swaybar disconnect weak link?
    By jhires in forum Jeep JK Wrangler
    Last Post: 10-04-2015, 03:37 AM
  4. NoLimits Manual Rubicon Swaybar Disconnect
    By Prime in forum Jeep JK Wrangler
    Last Post: 09-12-2013, 01:34 PM
  5. EVO NoLimits Manual Rubicon Swaybar Disconnect
    By Spartan in forum General Jeep Stuff
    Last Post: 08-17-2013, 03:47 PM
