Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: 35's and re-gear dliemma
  1. #21
    Been Around the Block PokerStogey's Avatar
    Join Date
    Apr 2016
    Location
    Bakersfield
    Posts
    422
    2016 JKUR HardRock Auto with 4.10 leveled out with 35” STT Pros.... drive it everywhere, even put all my gear and RTT into a military trailer and took a two week trip theough CA, OR and NV... never felt like I needed to regear. I do however, manually shift on long grades through mountains if that makes a difference to you.
  2. #22
    Fresh Catch
    Join Date
    Jul 2019
    Location
    Portland
    Posts
    27
    I just wanted to follow up with my experience.
    After 33K miles on 33's, I recently did a bunch of upgrades (including moving to KO2 35's) prior to a 3600 mile road trip to Moab. When I asked for advice here the bottom line good advice I got was "Drive it before you consider re-gearing and see what YOU think". So I did, and I am reporting back. First off, my JKUR has stock 4.10s, and is HEAVY (winch, bumper, full underbody armor, steel steps/rock rails, and it was full to the roof on the trip--CO2 tank, tons of tools/recovery gear, heavy cooler, steel link snow chains, 6 gallons of water, 12 gallons of gas in two cans, hi lift, etc.). There are a few attempts to save weight (aluminum bumper, synthetic winch line, 2 of the skids are aluminum) but it still is heavy, especially loaded for the road trip.
    My milage went up between 2.5 to 3 mpg at the same speeds vs when I was on 33's--just like gearing cars for economy versus power. Speed limits in ID and UT are 80, and I was cruising at 85 without significant problems (in fact I think the 35's help as it makes the effective gearing more appropriate). Also did some almost 10K mountain passes without issues.
    Rock crawling the power seemed just fine--this includes the very steep fins on Fins and Things and Hells Revenge, as well as some gnarly sandy climbs in Lavender canyon.
    Power off the line is a little less but not bothersome (and I have some very powerful cars and was a high performance driving instructor for 15 years, so I don't abide vehicles that can't get out of their own way). City milage before the trip is also improved.
    Bottom line is, at this point, I have no plans to re-gear. I may never know what I'm missing, but hopefully this may reassure some who think it has to be done.
    Now, 35's introduce other issues (braking is one) that aren't impacted by re-gearing that are separate considerations. (I redid both my front and rear brakes--Mopar BBK front, Dynatrac rear--freaking amazing.)
    As always, YMMV.
  3. #23
    Nothing but a Thing jorgelrod's Avatar
    Join Date
    Sep 2013
    Location
    Jacksonville, FL
    Posts
    1,862
    Quote Originally Posted by 64Chevy View Post
    As always, YMMV.
    Great to hear!
  4. #24
    Fresh Catch
    Join Date
    Nov 2019
    Location
    Hailey, Idaho
    Posts
    3
    As always, YMMV.
    That was my experience too with stock 4:10 and 35" tires. I got better fuel economy and barely noticed the power loss unless I was climing a long grade. I will regear when I make the change to 37" tires this winter. Thinking of 4:88 but leaning towards 5:13. Otherwise totally happy with my 35" tires and stock gearing.
  5. #25
    Old Timer Clutch's Avatar
    Join Date
    Dec 2015
    Location
    STL metro
    Posts
    2,778
    Yea, I think it’s one of those things where you don’t know until you know. I have stock gearing and 35s with beadlocks and don’t have any issue with the power output, I actually like it better than stock tires on the 4.10 gears.
  6. #26
    Knows a Thing or Two -AINOKEA-'s Avatar
    Join Date
    Oct 2011
    Location
    Hilo, HI
    Posts
    738
    I ran 35s on 3.73s for a couple of months and hated it. Driving a manual, 6th gear was useless even on flat highway and I wore out the clutch pretty bad.
  7. #27
    Fresh Catch georgieboy13's Avatar
    Join Date
    Nov 2019
    Location
    Los Angeles
    Posts
    13
    I regear'd my Rubi to 4.88 along with additional suspension upgrades before even putting on 35's. Huge difference uphill and especially crawling over boulders in 4l only loss 2mpg, worth every penny. 4.88 is perfect for 35-38 tires, now axles, brakes and steering is another thing.
  8. #28
    Fresh Catch Pazitive44's Avatar
    Join Date
    Oct 2013
    Location
    NJ
    Posts
    6
    4.56 turned my 2015 JK w 35's into a Rocket...
    Overdrive now works...Not a Slug anymore.
  9. #29
    Addict Brute's Avatar
    Join Date
    Nov 2015
    Location
    HI & WA
    Posts
    7,724
    Ok...I have a 2015 JKU with a 5.7, 5 speed auto and 35" BFG KM2's. With the original gearing of 4.10, I took my family on a trip from Seattle into Wyoming several years ago towing my Xventure trailer...and it was a dog going thru the mountain passes. After returning, I had it regeared to 4.56, knowing I had no intention of moving into bigger tires with this jeep. I eventually shipped it to HI where I now use it as my daily driver...and in hindsight, wished I had regeared it to 4.88 instead. It gets along fine , but it's no "rocket", even with a 5.7 hemi...even took it on the Rubicon trail prior to shipping it to HI...
  10. #30
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,818
    Quote Originally Posted by Brute View Post
    I don't think a single person has ever said I wished I had gone with a higher gear ratio. But many (like you) have said they wished that they had gone a step or two lower.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
Similar Threads
  1. Ten Factory (Motive Gear) 4.56 gear set with master kit.
    By TxCoastie in forum FOR SALE (Active Members ONLY)
    Last Post: 10-20-2018, 04:55 PM
  2. 35's need to re-gear?
    By Jaimegomez8 in forum Jeep JK Wrangler
    Last Post: 02-24-2016, 03:39 AM
  3. Re-gear 4:88's or 5:13's?
    By LAJK in forum Jeep JK Wrangler
    Last Post: 01-28-2016, 02:56 AM
  4. Tire Size, Gear Ratio and Gear Oil
    By angrymuffin in forum Jeep JK Wrangler
    Last Post: 11-05-2014, 08:04 PM
  5. Top gear us
    By firecrew1 in forum General Jeep Stuff
    Last Post: 07-10-2014, 07:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
