Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: UJoint Considerations for Axle Upgrade
  1. #11
    Knows a Thing or Two Seahawkfan's Avatar
    Join Date
    Oct 2016
    Location
    San Jacinto CA
    Posts
    729
    Quote Originally Posted by JJ151 View Post
    Like you I just installed the XD60s front/rear w/37s on my 2016 JKUR and replaced my stock Rubicon axles that had 4.10 gears. I went with 1350 drive shafts, which are working fine so far. As far as gears, I too, was concerned about 5.13s on the highway and my RPMs are close to 3k at 70 on the highway. However, with the added weight I am very glad I went with 5.13s and believe I would not be happy with the performance of 4.88s.
    That seems high..I was running almost 3k@ 75mph when I had my 35's and 5.13's now with 37's 2400 to 2500
  2. #12
    Hooked JJ151's Avatar
    Join Date
    Aug 2018
    Location
    Oregon
    Posts
    127
    Quote Originally Posted by Seahawkfan View Post
    Gear ratio chart for 3.6L w/auto w/37s shows 2,708 at 70 mph. I’m a bit above that. I may need to recheck my Procal setting.
    Even manual chart shows 2,600 rpm w/5.13 and 37s though.
  3. #13
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,859
    This is all good info. I'm going to 37's and will need a regear. I've looked at the charts and was himming and hawing between 4:88's or 5:13's. I was set on 5:13's, but was beginning to second guess this being that I have a manual. I think I'm back to going with 5:13's. I plan on installing a 1350 front when I do the regear. Now to find the time to get those tires installed..haha. Also will be a good time to address the t-case front output shaft leak I just discovered. Pretty sure I just need to put some rtv on the t-case yoke. Looks to be a slow seep that slings onto the under carriage.
  4. #14
    Hooked Noble Woodsman's Avatar
    Join Date
    Jul 2019
    Location
    Houston, TX
    Posts
    227
    This takes more power to overcome than stock tires, so the engine needs to be where it can make that amount of power easily
    This is a great point, which I had not considered. Thanks for helping me make this decision. Definitely ruling out the 4.88s based on everyone's feedback so far.
    Yes, the axle U joints are bigger, but there is the added gear reduction in the differential to multiply the torque before it gets to them, so they need to be stronger.
    Ok, this is making sense now. I figured the gear reduction needed to be considered somehow. I seem to hear about ujoint failures on the axle shafts more often than on the driveshafts, and this logic also seems consistent with that observation.
    JJ151, what wheels did you decide to go with for the XD60? It sounds like my build will have a similar drive train as yours.
  5. #15
    Join Date
    Oct 2016
    Location
    San Jacinto CA
    Posts
    729
    Quote Originally Posted by jesse3638 View Post
    I had a T-case leak after installing front 1350. Tried twice with the RTV ended up replacing the seal. Good to go. It was bitch finding the correct one. Some have a double seal and some single. Something like that. If I remember correct the color (Light Blue) of the seal ring had something to do with finding the right one. This was on non-Rubi 3.8
  6. #16
    Join Date
    Oct 2016
    Location
    San Jacinto CA
    Posts
    729
    Yea I'm in a 3.8 w/ Superchip Programmer. I was actually amazed at the difference in RPM when I finally went to 37's . Oh MPG didn't change much at all.
  7. #17
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,712
    You don’t hardly drive your Jeep, go 5.13’s. You will be able to hold the grade to mammoth in 5th gear at 80+ and accelerate going up it.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  8. #18
    Join Date
    Aug 2018
    Location
    Oregon
    Posts
    127
    JJ151, what wheels did you decide to go with for the XD60? It sounds like my build will have a similar drive train as yours.[/QUOTE]
    I chose the Hutchinson Rock Monster beadlocks for several reasons. First, I wanted a wheel with a significant backspace to maximize my scrub radius and keep wheels tucked as much as possible. Second, I wanted a beadlocks wheel that I could more easily change. As these are a two piece wheel there is no need to force the tire over a bead of the rim. Third, I like the fact that it locks both the inner and outer bead.
  9. #19
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,859
    Quote Originally Posted by OverlanderJK View Post
    It gets driven more now that we have 3 licensed drivers in the house. Yeah I figured I'd benefit more from the lower (5:13) option considering my use. It's going to be going back and forth to Barstow a couple times a week now for my new job. It'll get at least 120 miles a week now..haha.
Similar Threads
  1. Axle upgrade ..
    By danford.lau in forum Jeep JK Wrangler
    Last Post: 07-15-2018, 01:20 PM
  2. Driveshaft ujoint size opinions
    By xflstl in forum Jeep JK Wrangler
    Last Post: 04-22-2016, 02:07 AM
  3. Axle Upgrade
    By 94YJBeaver in forum Jeep TJ & YJ Wrangler
    Last Post: 02-23-2013, 10:35 PM
  4. Solid Spicer Ujoint?
    By jkjurny in forum Jeep JK Wrangler
    Last Post: 01-31-2013, 06:10 AM
  5. TJ Considerations
    By Ret Vet 007 in forum General Jeep Stuff
    Last Post: 12-19-2012, 11:29 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
