Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Greasing
  1. #11
    Fresh Catch
    Join Date
    Nov 2016
    Location
    RI
    Posts
    23
    Quote Originally Posted by WJCO View Post
    A couple people here have found that the grease fitting bottoms out and won't let the grease move through it. So by loosening the fitting a turn or two, the joint then takes grease.
    Iím going to try and loosen the few zerks Iím having problems with. Sounds like thatís my problem.
    Quote Originally Posted by USMC Wrangler View Post
    Iíve had the same problem but it was my grease gun tip. Grabbed a new one and itís better, but also have had to loosen a couple zerks.
    FLCA can be greased more easily with a mod or two, even on factory axles. Check this out...
    https://wayalife.com/showthread.php/...asing-Solution
    2013 JKU Sport S, named Spider
    http://wayalife.com/showthread.php?2...ker-quot-build
    Whoa... Thank you for the link. Looks like Iíll be drilling some holes next weekend.
  2. #12
    Old Timer USMC Wrangler's Avatar
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    4,207
    Quote Originally Posted by mayday_soc View Post
    Glad to help! I did it on my D30 and installed the low profile zerks. So much nicer than dropping them every time.
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    DIY trail/tube door build http://wayalife.com/showthread.php?24449-My-DIY-Doors
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  3. #13
    Addict wjtstudios's Avatar
    Join Date
    Nov 2016
    Location
    Rochester, MI.
    Posts
    6,104
    Quote Originally Posted by nbunga View Post
    Is it the lock n lube
    Yeah, thatís what it was. Thanks Andy
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
Similar Threads
  1. Best grease for greasing suspension parts and drive shafts
    By bruggymonster in forum Jeep JK Wrangler
    Last Post: 10-05-2019, 06:01 PM
  2. Replies: 32
    Last Post: 09-04-2019, 12:35 AM
  3. Greasing Lower Dynatrac ProSteer Ball Joints
    By WJCO in forum Jeep JK Wrangler
    Last Post: 04-01-2019, 03:49 PM
  4. Greasing lower ProSteer ball joint
    By MacRubi2 in forum Jeep JK Wrangler
    Last Post: 09-17-2016, 07:22 PM
  5. Greasing Evo Front Lowers
    By Buster3479 in forum Jeep JK Wrangler
    Last Post: 04-05-2015, 06:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
