Results 1 to 4 of 4
Thread: Life Hack - Winch Controller Cover
  1. #1
    Knows a Thing or Two Primo82's Avatar
    Dec 2018
    IN
    706
    I purchased a Smittybilt X2O winch for my Jeep, and recently customized and affixed the controller to my no-winch delete plate. A couple of reasons for this, but mainly it was interfering with and rubbed the paint off my grill...
    Even though this is supposed to be an IP rated winch, I've read enough complaints about the elements getting into and screwing up the smitty controllers I decided to make a cover for it. Just to keep water/dust/mud off the switch and controller plug. I was initially going to sew a cover out of neoprene, but decided to think through other options (I cannot sew...). Ultimately a youth sized swimming cap came to mind. Seems to fit well and should keep the winch controller dry/mud free.
    Anyways, if you're winch isn't IP rated. Or you're just anal retentive and don't want your controller facing all the elements, this solution should work. Doesn't look tacky. Pic related if anyone is interested. Cheers WAL.
    Attached Images Attached Images
  2. #2
    Old Timer jdofmemi's Avatar
    Mar 2018
    Menifee CA
    3,760
    Simple and effective, what's not to like.
  3. #3
    Old Timer Snboarder113's Avatar
    Oct 2015
    michigan
    2,552
    How do you get to the free spool handle
  4. #4
    Dec 2018
    IN
    706
    Quote Originally Posted by Snboarder113 View Post
    I used wing nuts to replace the nuts on the back side of the no winch plate for easy removal (I cut the no-winch plate so the drivers side can come off). But honestly there is enough clearance I can get my hands in there to switch it without having to remove the plate.
Similar Threads
  1. Winch Cover
    By lemoncadebay in forum Jeep JK Wrangler
    Last Post: 09-29-2019, 08:15 PM
  2. Replies: 9
    Last Post: 06-11-2017, 11:39 PM
  3. Warn winch cover
    By GraniteCrystal in forum Wanted
    Last Post: 01-22-2017, 02:47 AM
  4. Winch cover or no?
    By OJK12 in forum General Off-Road Tech
    Last Post: 01-09-2017, 05:52 PM
  5. Magnets for winch cover
    By RamP in forum Jeep JK Wrangler
    Last Post: 04-21-2014, 12:12 AM
