Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: 35 Spline D44 Vs SF60?
  1. #31
    Fresh Catch UncleBud's Avatar
    Feb 2017
    Louisiana
    11
    So what I'm getting from this is heavy jeeps plus sticky rocks equals bad news with 38s to 40s correct? I'm a little out of place here because I have an early bronco but I've been checking out all the jeep forums because I'm putting a jk dana 44 front axle in my bronco. How much meat is left on the pinion with the dana 44 with 5.13s? I'm running quite a bit more power than a typical jeep and actually have really light weight rig. I'm in Louisiana so all I deal with is mud and will be using my bronco to drag along a little lifted 8ft equipment trailer through job sights to maintenance my excavator and have a little fun at the beach.
  2. #32
    Knows a Thing or Two -AINOKEA-'s Avatar
    Oct 2011
    Hilo, HI
    707
    Quote Originally Posted by UncleBud View Post
    How much meat is left on the pinion with the dana 44 with 5.13s? .
    Not enough. Pinion gets tiny.
  3. #33
    Addict BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    5,621
    5.13 is as low as you'll want to go on the D44, but if you've got more power and you plan on running 40s, you're gonna want to go with a D60 for sure, if not a D80, depending on what your setup is.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  4. #34
    Feb 2017
    Louisiana
    11
    Quote Originally Posted by -AINOKEA- View Post
    That's what I needed to know thanks. Looks like I'll be doing 4.88s
  5. #35
    Feb 2017
    Louisiana
    11
    Quote Originally Posted by BaddestCross View Post
    In all honesty I was doing a dana 60/sterling 10.5 swap initially. Packaging was a nightmare in my bronco due to the extremely narrow frame. I sold off all my 1 ton stuff when I messed up the front axle housing. (Had to move the pumpkin more to passenger side and narrow at the same time). I miss measured and narrowed to much. I have no desire to do that over when I can build some y link arms and pretty much bolt up one of jk dana 44s. I honestly would rather run 37s but my bronco is already cut for 42s lol. Wont look to good lol
  6. #36
    Aug 2016
    Palmdale, CA
    5,621
    Get good at setting up gears then because you'll be doing it often.
  7. #37
    Oct 2011
    Hilo, HI
    707
    Sorry for a d44, 5.13 isn’t too bad. But if you’re gonna be running 38s or 40s you might want a little more meat on there. Also 38s or 40s will put a ton of stress on a 44 in various areas, especially with more power. I’d probably go with a 60.
  8. #38
    Old Timer fiend's Avatar
    May 2017
    SoCal
    3,660
    The 44 can handle increased horsepower. They put them in corvettes, for example. The issue is going to be the pinion. I higher HP applications they’re using ratios like 3.08:1. Once you’re at 5.13, the pinion is smaller and the gear set weaker. Depending on your transmission and wheel size, you maybe can get away with a 4.56 or 4.88. The smaller the ratio the larger the pinion gear the stronger the gear set.
  9. #39
    Feb 2017
    Louisiana
    11
    Quote Originally Posted by fiend View Post
    I have a 35spline built 9" for the rear so honestly that's going to take 90% of the brunt. I just need the 4wd for when it gets slick.
  10. #40
    Feb 2017
    Louisiana
    11
    Just to show I was being serious about the 60 swap. That was my initial goal.
    Attached Images Attached Images
Similar Threads
  1. Upgrade to 35 spline?
    By BeardedJK in forum Jeep JK Wrangler
    Last Post: 10-25-2018, 03:34 AM
  2. 35 spline vs 30 spline
    By Mybadjk in forum Jeep JK Wrangler
    Last Post: 02-06-2017, 07:03 PM
  3. 35 Spline Vs 30 Spline axles?
    By Mkp08 in forum Jeep JK Wrangler
    Last Post: 03-30-2016, 12:29 AM
  4. FS: D35 ARB 30 spline
    By BumpStick in forum FOR SALE (Active Members ONLY)
    Last Post: 10-13-2015, 10:45 PM
  5. G2 Gold 35 Spline 4130 or Nitro 35 Spline 4130 deep heat forged
    By Livin4Today in forum Jeep JK Wrangler
    Last Post: 10-14-2013, 04:52 PM
