Results 1 to 6 of 6
Thread: Cj-7 Radio antenna help
  1. #1
    Been Around the Block Spazbyt's Avatar
    Oct 2015
    St.Peters, MO
    423
    So in my infinite wisdom I removed my old AM/FM radio antenna of my 1986 Cj-7 and trashed it. I was figuring I would easily find a OEM replacement. My old antenna mount was round but the only "OEM" replacements I can seem to find are triangular shaped antenna mounts. Now its entirely possible that my antenna was a aftermarket replacement. My best guess would be the triangle mount was on later models and the round mount was something on newer Cj's?
  2. #2
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    6,652
    My 85’ is a triangle if that helps.
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  3. #3
    Oct 2015
    St.Peters, MO
    423
    [QUOTE=wjtstudios;1166786]My 85’ is a triangle if that helps.
    It does, thank you. Looks like I had a aftermarket replacement then.
  4. #4
    Nov 2016
    Rochester, MI.
    6,652
    No problem!
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
  5. #5
    Fresh Catch
    Aug 2019
    Newcastle, California (CA)
    4
    Rectangle mount
    Quote Originally Posted by Spazbyt View Post
    My '84 CJ-7 also has the rectangle mount and it's mounted up in that space just under the top door hinge mount.
  6. #6
    Nothing but a Thing TOPLESS's Avatar
    Mar 2015
    Benton Harbor, Michigan
    1,353
    Just looked at old pic of my 84 and it was rectangular too.
Similar Threads
  1. Replies: 20
    Last Post: 01-18-2020, 05:49 PM
  2. Replies: 4
    Last Post: 09-05-2018, 04:32 AM
  3. Best Ham Radio Mobile Antenna
    By KJs JK in forum General Jeep Stuff
    Last Post: 06-04-2018, 08:58 AM
  4. Rugged Ridge CB Radio and Antenna Mounting Kit Write-Up
    By WxNerd2015 in forum JK Write-Ups
    Last Post: 10-08-2015, 02:55 PM
