Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Thread: Is there a way to reset computer to relearn shift points?
  1. #21
    Addict jesse3638's Avatar
    Sep 2012
    Apple Valley, CA
    5,876
    Quote Originally Posted by AgBass01 View Post
    Yes, I used a well respected local shop that has helped me out on numerous occasions with little issues here and there.
    Good to know Bubba. Sounds like I just need to bite the bullet and get a programmer of some sort and get my tires done sooner rather than later.
    Just go with the jscan app. Seems to be a really good option and more comprehensive than some of the more expensive options out there.
  2. #22
    Hooked AgBass01's Avatar
    Sep 2019
    Round Rock, TX
    163
    Quote Originally Posted by jesse3638 View Post
    That's what I was gonna do.
  3. #23
    Been Around the Block kyle521's Avatar
    Apr 2013
    United States
    280
    Ok. Thanks for the info. I'll give them a call. I've been looking at the bluetooth OBDII adapter and jscan app as well, might just pull the trigger and check it out myself.
    I went this route, the JScan app is great also for reading and clearing codes in addition to the tires and gear ratio. For some reason the app did not work on my old phone but works on my newer Ipad. I went with the Veepeak for the obd port blue tooth reader
  4. #24
    Sep 2019
    Round Rock, TX
    163
    Quote Originally Posted by kyle521 View Post
    Just ordered the vgate 4.0, gotta love Amazon free delivery tomorrow.
  5. #25
    Old Timer USMC Wrangler's Avatar
    Feb 2015
    Cochise County, AZ
    4,219
    I had a similar issue earlier this year. It wouldn’t shift but not sure if it was technically limp mode.
    https://wayalife.com/showthread.php?t=56589
    It took 2-3 times of programming the gear ratio to get it right.
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  6. #26
    Hooked Turbo21's Avatar
    Jun 2018
    Baldwin
    198
    I have been having the same issue since changing to 5.13 gears. 3-4th gear up a hill likes to run at about 5500 rpm before shifting and I have even used the auto stick to force a shift. Gears and tire size were set with flash cal. I just used the OBD adapter and JScan to rewrite the gears I’m heading out in a bit and hopefully that changes something I will update back
    From all the googling I have done it seems like a pretty common problem when changing the gear ratio with the flashcal. A lot of people have had to take it to the dealership for a flash then rewrite again with flashcal before the shift points were at a more normal range
  7. #27
    Caught the Bug 17xJKU's Avatar
    Mar 2018
    Northern KY
    78
    I have the flashcal, went from stock tires, 3.21 gears to 37s with 4.88 gears. It shifts okay I think for the weight and tires, but there are times it really holds the gears and I use the auto stick to shift. I thought it was just normal, but it does bug the crap out of me.
    Sent from my SM-N950U using WAYALIFE mobile app
  8. #28
    Sep 2019
    Round Rock, TX
    163
    Got the jscan all setup and verified that gears ratio is set to 4.56. Also updated the tire size. Will see how things run tomorrow.
  9. #29
    Jun 2018
    Baldwin
    198
    No change after rewriting using jscan. Only seems to hold the gear when going up hill from 3rd-4th. 5500 rpm before shifting
  10. #30
    Addict BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    5,928
    Quote Originally Posted by Turbo21 View Post
    You did set measured tire size, right? Measure from the ground to center hub then multiply by 2... Sidewall printed size doesn't work.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
Similar Threads
  1. Instrument Cluster Reset(?)
    By Spencer11496 in forum Jeep JK Wrangler
    Last Post: 02-29-2016, 08:57 PM
  2. Disconnecting battery to reset my jeep?
    By Ant's JK in forum Jeep JK Wrangler
    Last Post: 07-28-2014, 02:49 PM
  3. 3.6 shift points
    By Sugarbear in forum Jeep JK Wrangler
    Last Post: 12-22-2013, 03:06 AM
  4. AEV Procal - reset to remove VIN
    By pastorwug in forum For Sale
    Last Post: 11-01-2013, 03:19 PM
  5. 2013 TMPS Reset
    By Skid_Kid in forum Jeep JK Wrangler
    Last Post: 02-16-2013, 01:21 AM
