Results 1 to 5 of 5
Thread: 16s on jl?
  1. #1
    Knows a Thing or Two robx251's Avatar
    Mar 2013
    Central Maine
    807
    16s on jl?
    So I have access to a set of jk factory 16s that have 35s on them, does anyone know if I can use these as a set of play wheels for my jl and keep my Rubicon wheels and tires for daily driving or will I run into clearance issues on three brakes? I know the bolt holes would need to be drilled out
  2. #2
    Nothing but a Thing RockinAZJK's Avatar
    May 2016
    Waco, Texas
    1,450
    Quote Originally Posted by robx251 View Post
    I mean I suppose you could drill the lug holes out, BUT they are supposed to have a specific seat to mate with the lugnut.
  3. #3
    Mar 2013
    Central Maine
    807
    Quote Originally Posted by RockinAZJK View Post
    Being for trail use only I'm not too concerned about being perfectly centered and I would use a specific set of lug nuts just for those wheels as top not mess up the ones for the aluminum wheels. But I'm more curious about the interference issues. If it won't fit then no worries but if they do that's a plus.
  4. #4
    Been Around the Block Bustedback's Avatar
    Apr 2015
    NorCal
    379
    I wouldn’t recommend altering a wheel, even for trail use only. There’s just too much liability if something were to happen.
  5. #5
    Caught the Bug cpefy3's Avatar
    Dec 2014
    Raleigh, NC
    54
    Easiest solution is to buy a set of wheel spacers to avoid any rubbing. I think both the JK and JL are 5x5 so the lugs should line up. Good Luck!!
