Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Tow rig just stopped running
  1. #1
    Caught the Bug A JK 2010's Avatar
    Join Date
    May 2014
    Location
    Leadville Colorado
    Posts
    87
    When it rains it pours. Been hit with some rough times and now just received another blow. I was taking my SXS to the shop yesterday and my 02 2500HD just stopped running. Truck was running for about 15-20min before I left town. About 5 miles out of town I was passing a car doing 65 than I lost power so I pulled over to the side of the road No loud noise no check engine light came on nothing and now it wonít start. I tried priming it and didnít start. It has been getting a bit colder in Leadville Colorado but not sure if that is the problem I did tow it home with the Jeep today
    I donít have any idea when it comes to a diesel this is my first one
    Thanks for the help
  2. #2
    Fresh Catch Gburow82's Avatar
    Join Date
    Sep 2019
    Location
    Victoria
    Posts
    10
    When is the last time you filled up? I'd change filters at the minimum to start with and go from there.
    Sent from my SM-G975U using WAYALIFE mobile app
  3. #3
    Caught the Bug GraniteWilly's Avatar
    Join Date
    Oct 2017
    Location
    Seattle
    Posts
    84
    The first thing that comes to mind is the fuel filter. Otherwise cold weather can impact glow plugs, but if it was running fine earlier thatís probably not it.
    Iím no expert, but with a diesel if it turns over itís usually a fuel problem.
  4. #4
    Addict TrailHunter's Avatar
    Join Date
    Apr 2016
    Location
    SoCal
    Posts
    5,238
    Something similar happened to me in my 05.... was headed out of town to AZ and the truck started to lose power... it slowly got worse until I was in the middle of no where in 120 degree heat. Luckily my buddies Father was with us and he is an old school mechanic. After about an hour we realized the primer pump on the fuel filter was not holding pressure. The O-ring on the pump was shot. He took some construction string I had and wrapped a thin strand where the o-ring sits so when we put the o-ring back on it made a good seal... Pumped the primer... held pressure and we were on our way.... I ended up ordering a whole new pump assembly and swapped it out myself. I bet it's a bad primer pump.
  5. #5
    Join Date
    May 2014
    Location
    Leadville Colorado
    Posts
    87
    Quote Originally Posted by Gburow82 View Post
    On Wednesday
  6. #6
    Join Date
    May 2014
    Location
    Leadville Colorado
    Posts
    87
    [QUOTE=TrailHunter;1168756]Something similar happened to me in my 05.... was headed out of town to AZ and the truck started to lose power... it slowly got worse until I was in the middle of no where in 120 degree heat. Luckily my buddies Father was with us and he is an old school mechanic. After about an hour we realized the primer pump on the fuel filter was not holding pressure. The O-ring on the pump was shot. He took some construction string I had and wrapped a thin strand where the o-ring sits so when we put the o-ring back on it made a good seal... Pumped the primer... held pressure and we were on our way.... I ended up ordering a whole new pump assembly and swapped it out myself. I bet it's a bad primer pump.
    [ATTACH=CONFIG]
    When I prime it it leaks out of it Is that normal? It has a fuel/water separator on it as well. I remember the dealer saying it has a lift pump as well not sure if that could be it.
    I was thinking of replacing the filters and added some diesel Kleen I donít think that would hurt
  7. #7
    Join Date
    May 2014
    Location
    Leadville Colorado
    Posts
    87
    On the bottom of the fuel pump it wasnít plugged in. So I plugged it in but the batteries are dead so I will charge them and see it it was just a simple plug that came disconnect
  8. #8
    Join Date
    May 2014
    Location
    Leadville Colorado
    Posts
    87
    Plugged it back in lest see what happens once I charge the batteries 🤞🏽
  9. #9
    Join Date
    Apr 2016
    Location
    SoCal
    Posts
    5,238
    Doesn't your truck alert you when the filter needs to be changed? It should tell you the % life of the filter.... if you don't change it, that could cause issues as well. That's weird that it was unplugged.
    There is a small plastic screw at the top of the pump.... you loosen the screw and start pumping.... once you feel pressure and fuel starts to come out of that screw... tighten the screw. There should not be leaking other than that. If there is any pressure loss, your truck will not run.
  10. #10
    Join Date
    May 2014
    Location
    Leadville Colorado
    Posts
    87
    Quote Originally Posted by TrailHunter View Post
    No my truck doesnít have a percentage indicator I do see the screw on top but that filter is very loose so I will tighten it charge the batteries and try in the am.
Similar Threads
  1. Replies: 4
    Last Post: 12-12-2017, 02:10 AM
  2. Has Zoro stopped carrying Zeon?
    By CarolinaJK in forum General Jeep Stuff
    Last Post: 07-29-2015, 01:27 AM
  3. Stopped by the Pinion Nut
    By jeeeep in forum Jeep JK Wrangler
    Last Post: 02-24-2014, 07:11 PM
  4. Stopped by the Toledo Jeep plant yesterday
    By pedro2009 in forum General Jeep Stuff
    Last Post: 05-30-2013, 09:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
