Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Stubborn Check Engine Light
  1. #11
    Old Timer sipafz's Avatar
    Mar 2015
    Saukville, Wisconsin
    2,565
    Check the evap. hoses! They dry rot and leak over time.
  2. #12
    Hooked Primo82's Avatar
    Dec 2018
    IN
    245
    Quote Originally Posted by sipafz View Post
    Yea, I looked at his profile after my last post. Looks like this is happening on a 90s TJ. Dry rot is definitely likely.
  3. #13
    Fresh Catch
    Sep 2019
    Missouri
    7
    Gas cap was first fix. Obviously didnt work. Thanks for the vote of confidence.
    Sent from my SM-G975U using WAYALIFE mobile app
  4. #14
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    1,500
    Key on/off/on/off/on see if the dash will Show you a code.
    Smack your gauge cluster inwards, they have crappy connection design.
    Unplug and clean harness connections at computer above the battery. Ensure seated properly.
  5. #15
    Fresh Catch
    Sep 2019
    Missouri
    7
    If anyone cares, this was my stepwise process:
    1. Idle air module/valve.
    2. Purge solenoid valve
    3. Vapor canister
    4. Had a dry rotted elbow from VC to intake.
    At this point, none of the fixes got rid of the light. My last choices were horses (they were all good), MAP sensor, and new PCM.
    5. Replaced MAP sensor. Light immediately went off.
Similar Threads
  1. Check engine light
    By ZachP in forum Jeep JK Wrangler
    Last Post: 08-13-2019, 10:45 AM
  2. Check engine light
    By DanJK2007 in forum Jeep JK Wrangler
    Last Post: 09-14-2017, 10:52 AM
  3. Replies: 0
    Last Post: 08-24-2017, 11:24 PM
  4. TJ check engine light
    By Gadget in forum Jeep TJ & YJ Wrangler
    Last Post: 03-02-2015, 10:31 PM
  5. TJ check engine light
    By Gadget in forum The 8th Slot
    Last Post: 03-02-2015, 03:44 PM
