Results 1 to 3 of 3
Thread: Hydroboost Frozen Caliper and Leaking PS Cap/Box
  1. #1
    Fresh Catch
    Mar 2019
    Gilbert AZ
    9
    Had a caliper freeze up on me on the trail (back passenger side) but didn't really notice until I was at the highway to air up. I noticed my power steering cap had been leaking and my steering box was leaking. I figured because I have a hydro boost system on this CJ when the caliper froze the system needed to relieve pressure so it came out of those two spots. 1980 master cylinder with Hydroboost from an Astro can. Brakes are disk on the back and it is a stock steering box with brackets for support. Running 37” tires. What do you think?IMG_2895.JPG
  2. #2
    Fresh Catch
    Mar 2019
    Gilbert AZ
    9
  3. #3
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,740
    I think you have two different issues.
    The hydroboost system just allows the driver to have less pedal effort while applying brakes. If a caliper locked up, when you push the brakes, your brake fluid pressure would just go to the other 3 wheels.
    The power steering leaks you have are likely just leaks that occurred over time. The one at the pump has been leaking for awhile. May want to clean that one up and recheck it, it could just be someone spilled fluid at some point and didn't wipe it up.
Similar Threads
  1. WK Frozen Window Washers
    By Coop in forum Jeep Cherokee & Grand Cherokee
    Last Post: 01-06-2017, 03:16 PM
  2. FROZEN Soap Bubbles - Anyone Do This Before?
    By wayoflife in forum The 8th Slot
    Last Post: 01-14-2016, 06:04 AM
  3. hydroboost brakes
    By dahreno in forum General Off-Road Tech
    Last Post: 12-13-2013, 05:46 AM
  4. Door Handle Frozen
    By Jeepmaverick in forum Jeep JK Wrangler
    Last Post: 12-07-2013, 02:35 AM
  5. A big frozen wave from Minnesota!!
    By msweeney in forum Give us a Wave
    Last Post: 01-06-2013, 03:38 AM
