Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Hole in oil pan
  1. #21
    Hooked Noble Woodsman's Avatar
    Jul 2019
    Houston, TX
    130
    Quote Originally Posted by Ddays View Post
    That'd be pretty hard to accomplish unless there was a catastrophic failure. And for that to happen twice?
    Attachment 336539
    Yep. I was trying to brainstorm why the hole would appear in the same location twice. Throwing bolts internally seems unlikely to hit the same spot twice. It's sounding more like the hole was patched and the latch failed, as was suggested by others.
  2. #22
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    7,742
    Quote Originally Posted by 19YJ94 View Post
    As fun as that can be, mines running good. Maybe we can pull out your electrical system/wiring harness?
    Lol, that’s next if this tipm doesn’t work
  3. #23
    Feb 2013
    Leo, Indiana
    7,742
    Quote Originally Posted by Exodus Jeeps View Post
    I hear some shops just rtv the hole...
    Only if it looks like a weld bead
  4. #24
    Caught the Bug quertyman's Avatar
    Jun 2015
    United States
    71
    I've had this happen to me. A while back I had a truss welded onto the axle and went wheeling where I bent my upper control arm. The axle shifted back and the truss ran into my oil pan. Didn't notice until I was heading home on the freeway and the engine cut and I found the oil trail going down the road.
  5. #25
    Fresh Catch bhawghead's Avatar
    Jan 2013
    ky
    31
    Okay, I think I finally have all the answers to this debacle. He says his mechanic told him the bolt holding the lower timing chain sprocket came out causing the initial hole in the front, which he told me last month he had a new head and timing chains installed because of a collapsed lifter and stuck valve, this i did not know. The second hole was actually not in the same place, it was actually the weep hole in flywheel cover he was seeing. After they replaced the oil pan and "bolt", they failed to seal the pan in the rear properly which started pouring oil. Thanks for all the helpful tips though, he had me stumped when he was explaining all this to me.
    2007 "Steel Blue" JK Sahara
    2012 Silver JKU RHD(sold)
    2016 Hydro Blue JKU RHD(sold)
    2017 Chief Blue JKU RHD
  6. #26
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,730
    Quote Originally Posted by bhawghead View Post
    ... the bolt holding the lower timing chain sprocket came out causing the initial hole in the front, which he told me last month he had a new head and timing chains installed because of a collapsed lifter and stuck valve,
    So is he going to take the oil pan bill to the first shop that did the timing chain work and have them pay for it? Sounds like they left a bolt loose when they did the timing repair.
  7. #27
    Been Around the Block Primo82's Avatar
    Dec 2018
    IN
    260
    I recommend he not look in the bottom of the barrel for a mechanic. These issues will continue to happen if he hires morons! Good luck to your friend on his warranty/small claims case!
    Edit: Being mostly sarcastic but god damn that's some shitty work.
  8. #28
    Hooked Jkratt's Avatar
    Apr 2015
    Santa Clarita
    151
    Glad it got solved and you are lucky the engine held together.
Similar Threads
  1. Want to overland? They will cut a hole for you!
    By NFRs2000NYC in forum Jeep JL Wrangler
    Last Post: 12-05-2017, 02:00 AM
  2. Exhaust Hole
    By bruggymonster in forum Jeep JK Wrangler
    Last Post: 05-12-2017, 03:15 AM
  3. My name is Tom and I'm an A$$hole
    By ITLL GO in forum The 8th Slot
    Last Post: 09-05-2015, 06:43 PM
  4. First hole..... o.O
    By JKWrang in forum General Jeep Stuff
    Last Post: 10-07-2013, 09:14 AM
  5. Mystery hole
    By Serg5000 in forum Jeep JK Wrangler
    Last Post: 11-01-2012, 02:42 AM
