Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Hole in oil pan
  1. #1
    Fresh Catch bhawghead's Avatar
    Jan 2013
    ky
    31
    Hole in oil pan
    My neighbor has a 2014 jk and recently had his engine overheat and start pouring smoke, after pulling over he sees oil pouring out the front of his engine and he looks and sees a quarter size hole in the top front of his oil pan, his shop said a bolt must have come out and came thru the oil pan, they replaced the oil pan and to his knowledge that is it. I know, i know.....i told him something had to come loose and create the hole, bolts aren't just free flowing throughout the engine, he just looks at me with a dumbfounded look. Well, long story short he gets it back today drives about 2.5hrs, and it does the exact same thing. What would be loose in the FRONT section of the engine right behind the balancer that could be knocking a hole in his oil pan, oil pick up maybe?
    2007 "Steel Blue" JK Sahara
    2012 Silver JKU RHD(sold)
    2016 Hydro Blue JKU RHD(sold)
    2017 Chief Blue JKU RHD
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,800
    First find out which way the hole is protruding. See if something from the inside outward did it or if something on the outside is hitting it.
  3. #3
    Nothing but a Thing MericaMade's Avatar
    Nov 2017
    SoCaL
    1,020
    LOL Fucking CSI over here. Good info!
  4. #4
    Old Timer TrailHunter's Avatar
    Apr 2016
    SoCal
    4,567
    Quote Originally Posted by MericaMade View Post
    Was the wife left alone with the Jeep at any time... an alibi might be needed for this investigation.
  5. #5
    Nothing but a Thing Angry Aussie's Avatar
    Jun 2013
    Austin
    1,473
    That sounds nuts. Keep us posted, really curious to know what’s causing this. Hopefully y’all can get it figured out soon.
  6. #6
    Nothing but a Thing jdofmemi's Avatar
    Mar 2018
    Menifee CA
    2,149
    My first thought is never go back to that shop.
    I've never been inside of one of these to know what might be suspect, but something is obviously coming apart. That said, there is nothing inside of any engine that can afford to loose a bolt or two without being on a short road to total destruction.
    I can't believe a reputable shop would not investigate far enough to find the source.
  7. #7
    Nothing but a Thing Coop's Avatar
    Jul 2015
    Ohio
    2,229
    Makes you wonder if the shop PATCHED the hole and the patch failed.
  8. #8
    Been Around the Block Primo82's Avatar
    Dec 2018
    IN
    278
    I'd love to see a pic of this. I agree with WJCO, identify which way the protrusion occurred. I also agree withe above statement. If the engine is flinging bolts at high RPMs it is not going to be a functional engine much longer... Your friend sleeping around with anyone's wife by chance? Sounds so strange it could be intentional..
  9. #9
    Hooked Jkratt's Avatar
    Apr 2015
    Santa Clarita
    153
    Should anything come apart in the bottom end of an engine, engine life ends. As the crank moves around anything loose would make a lot of noise. I agree, I would love to see a picture. Just does not make any sense. I really don't know what would be hitting the pan from the outside either. I would shake everything under the jeep near the pan to see if anything is broken or loose.
    Please keep us posted when you find out what it is.
  10. #10
    Nothing but a Thing RockinAZJK's Avatar
    May 2016
    Waco, Texas
    1,063
    This is so weird that it actually has my attention. With CSI Colorado in here it’s almost better than watching TV now!
Similar Threads
  1. Want to overland? They will cut a hole for you!
    By NFRs2000NYC in forum Jeep JL Wrangler
    Last Post: 12-05-2017, 02:00 AM
  2. Exhaust Hole
    By bruggymonster in forum Jeep JK Wrangler
    Last Post: 05-12-2017, 03:15 AM
  3. My name is Tom and I'm an A$$hole
    By ITLL GO in forum The 8th Slot
    Last Post: 09-05-2015, 06:43 PM
  4. First hole..... o.O
    By JKWrang in forum General Jeep Stuff
    Last Post: 10-07-2013, 09:14 AM
  5. Mystery hole
    By Serg5000 in forum Jeep JK Wrangler
    Last Post: 11-01-2012, 02:42 AM
