Results 1 to 5 of 5
Thread: Aggressive "shaking" in 4th gear. 6 spd manual
  1. #1
    Fresh Catch
    Join Date
    Feb 2013
    Location
    Alaska
    Posts
    27
    I have a 2012 manual Unlimited and when I am in 4th gear and give it gas the Jeep shakes aggressivly. I first noticed it the other day when I was just cruising in 4th and gave it gas to get up to speed. If I gradually get up in speed everything is fine and shifts in and out of gear smoothly, its more when I get on the gas pedal. When i ease off it gies away and then does it again if i "gun" it. If anyone has any insight that would be great! Thanks!
  2. #2
    Nothing but a Thing Snboarder113's Avatar
    Join Date
    Oct 2015
    Location
    michigan
    Posts
    1,529
    Does the shifter shake or is the entire jeep shaking. Only ever happens in 4th? Going through all the other gears and rpm ranges no other issues? Do you hear a loud clicking/snapping or a thumping feel like an impact gun? If you’re going like 25 shift Into 5th and floor it does the rpm go up?
  3. #3
    Fresh Catch
    Join Date
    Feb 2013
    Location
    Alaska
    Posts
    27
    Quote Originally Posted by Snboarder113 View Post
    the entire jeep shakes and i can only recreate it in 4th. All other gears work great. I dont hear anything except the jeep shaking. I will have to get back to you on the 5th gear and RPMs.
  4. #4
    Join Date
    Oct 2015
    Location
    michigan
    Posts
    1,529
    I think you have a driveshaft angle or balance issue that comes on at certain speeds/rpm and that’s just normally in 4th when it happens. Without more specific trans symptoms I doubt it’s a broken teeth or other internal issues.
    Could also be clutch chatter of a dieing clutch (especially if slipping) depending on your definition of aggressive shaking.
    Take a video if you can, will help to understand. .
  5. #5
    Fresh Catch cpefy3's Avatar
    Join Date
    Dec 2014
    Location
    Raleigh, NC
    Posts
    41
    I agree on driveshaft or driveshaft u joint issue. I would suggest pulling the front drive shaft and seeing if you still have the vibrations. Good luck!!
Similar Threads
  1. "Cheap" Warn vs "Top end" Smittybilt winch questions
    By HardRockRubicon in forum Jeep JK Wrangler
    Last Post: 09-26-2018, 02:48 AM
  2. Newbie question about "beadlocks" and "slabs"
    By Rubiconsean23 in forum Jeep JK Wrangler
    Last Post: 03-19-2017, 11:23 PM
  3. Replies: 43
    Last Post: 01-23-2017, 02:35 AM
  4. Replies: 39
    Last Post: 07-22-2016, 02:09 PM
  5. The "Gear Safe"
    By taJKUmal in forum Jeep JK Wrangler
    Last Post: 09-22-2013, 06:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
