Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Synergy Long Arm Clearance Question
  1. #1
    Hooked Noble Woodsman's Avatar
    Jul 2019
    Houston, TX
    227
    I may be going down a rabbit hole here, but I'm having trouble understanding the backspacing recommendation from Synergy for their stage 4 long arm kit (3" or 4/4.5"), and I am hoping someone running this suspension can help me visualize this.
    Synergy recommends a maximum backspacing of 4.75" with these LA kits to run 37x12.50R17 tires. I reached out to them to ask about this number, and and was told "our recommended backspacing is to clear the longer rear sway bar links and high steer drag link". Best I can tell from reviewing install videos, pictures, and the installation manuals, the rear sway bar links and high steer drag link/bracket seem to be the same dimensions as those found on the AEV DualSport 4.5" lift, which recommends up to 5.2" backspacing for the same tires. Would someone with the Synergy LA kit please post a picture of your setup showing the clearance between (1) the tires and rear sway bar links and (2) the tires and high steer drag link to help me understand what I'm overlooking? Please note what tire size and backspacing you're running for reference.
    Ideally, I'd like to run a BS of 5.2" (or anything larger than 4.75") with the Synergy LA kit to help reduce strain on the stock axle wheel bearings, and I want to see proof that it won't work before I completely rule this out. Thank you!
  2. #2
    Nothing but a Thing -AINOKEA-'s Avatar
    Oct 2011
    Hilo, HI
    1,133
    More backspacing pulls the tire closer to the axle instead of out and away from any components.
  3. #3
    Jul 2019
    Houston, TX
    227
    Exactly. I want to run more BS so the tires are tucked deeper under the fenders.
  4. #4
    Living the WAYALIFE wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    10,939
    With the 37s on stock width axles, you will rub the frame at full lock when turning. I ended up running 1.5” spacers to eliminate that with 4.5” back spaced wheels. I did clear the sway bar links.
    I do still run the AEV 4.5” springs and stock fenders and they barely clear there the 37 BFG KM2s.
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  5. #5
    Jul 2019
    Houston, TX
    227
    Quote Originally Posted by wjtstudios View Post
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    This is exactly why I am confused. I would expect the same arrangement you have to also fit the synergy kit, but your setup is equivalent to a 17x8.5 wheel with 6" of backspace (1.5 + 4.5), so why would Synergy recommend a maximum of 4.75" then? Is there something different between the synergy and evo LA kit clearances?
  6. #6
    Nov 2016
    Rochester, MI.
    10,939
    Quote Originally Posted by Noble Woodsman View Post
    Opposite actually. 4.5” minus the 1.5” so affectively I was running 3” of backspacing. Does that make sense?
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
  7. #7
    Oct 2011
    Hilo, HI
    1,133
    You have it backwards... it would be 4.5 - 1.5. So he’s running 3” backspacing.
    Edit: beat me to it. Lol
  8. #8
    Old Timer jdofmemi's Avatar
    Mar 2018
    Menifee CA
    3,840
    I don't have the long arm kit, but do have a comment.
    If you wheel in challenging places, having the wider track from less back spacing or adding spacers helps with stability to make off camber situations easier to tackle without getting tippy.
    Other things come into play, but I like to be wide.
  9. #9
    Jul 2019
    Houston, TX
    227
    Thanks guys! Yes, subtracting the wheel spacer thickness instead of adding it makes sense.
    This also clarifies my original question... AEV recommends a 1" wheel spacer if using stock wheels with the dualsport lift, which would be equivalent to 4.5" BS, and is consistent with most lift manufacturers recommendation, including synergy. AEV does offer a 5.2" BS wheel, but from what i can tell, most people use this wheel for 33" or 35" tires, not true 37". I guess with 37" tires, 4.5" BS still causes rubbing with factory flares.
  10. #10
    Jul 2019
    Houston, TX
    227
    Quote Originally Posted by jdofmemi View Post
    Agreed. I plan to upgrade to wider axles in the future, but in the meantime i will be upgrading to 35s on stock rubi axles and weighing 6000 lbs, so my immediate concern is reducing the maintenance required on the wheel hubs by keeping as large an offset as possible. This means narrow wheel and as large BS as possible.
    P.S. I know a LA suspension upgrade is overkill for 35s, but i'm building it now to eventually run 40s. When that time comes, i figure i will only need to replace coils and shocks on the suspension, which will make that upgrade cheaper and easier.
Similar Threads
  1. Replies: 12
    Last Post: 07-10-2017, 05:03 AM
  2. EVO high clearance long arm brackets
    By Spudcannons in forum Jeep JK Wrangler
    Last Post: 07-11-2015, 01:27 AM
  3. Evo high clearance long arm question.
    By jeeper52 in forum Jeep JK Wrangler
    Last Post: 04-19-2015, 11:49 PM
  4. High clearance long arm kit from EVO
    By Jerms in forum Jeep JK Wrangler
    Last Post: 12-28-2014, 01:07 AM
  5. Evo high clearance long arms
    By JK12 in forum Jeep JK Wrangler
    Last Post: 01-13-2013, 03:05 AM
Tags for this Thread
