Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: VIBRATION DAMPER transfer case
  1. #1
    Nothing but a Thing Slimebones's Avatar
    Dec 2015
    Front Range, Colorado
    1,231
    http://project-jk.com/jeep-jk-write-...r-case-service
    Am looking to rebuild my transfer case, 07 Rubicon. On back side of rear case half is a vibration damper as illustrated in first pic of Eddie's write-up on t-case service. My question is: how is this damper attached to t-case and can it safely be removed since Jeep did not use these on future builds?
  2. #2
    Addict Ddays's Avatar
    Aug 2015
    Darlington, Pa
    9,612
    Quote Originally Posted by Slimebones View Post
    Looks like it's held on by 3 bolts. It should come right off.
  3. #3
    Dec 2015
    1,231
    Quote Originally Posted by Ddays View Post
    Trying to figure out how this thing works. Can anyone explain?
  4. #4
    Addict BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    5,638
    Sorta like a gyroscope. It spins and keeps the thing it's spinning on even with no vibrations. Unless it's off balance, then you're fucked.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  5. #5
    Dec 2015
    1,231
    Quote Originally Posted by BaddestCross View Post
    I have been trying for some time now to find a diagram of how this applies. Can't find one. Does it go through the case here and attach to the front output shaft?
  6. #6
    Aug 2016
    Palmdale, CA
    5,638
    I don't know about the Jeep transfer case. I replaced one on my old S15 Blazer years ago that was attached to the crankshaft. I would assume the transfer case would be the same idea.
  7. #7
    Nothing but a Thing Speedy_RCW's Avatar
    Jul 2015
    Northern California
    1,975
    It’s attached by 3 bolts and can be removed with no issue. There is no spinning or anything like that that was mentioned. I actually installed one on my 2015 after long fight with vibrations.
  8. #8
    Jul 2015
    Northern California
    1,975
    No spinning. It’s literally just a heavy hunk of metal isolated in a bracket with a rubber bushing.
  9. #9
    Dec 2015
    1,231
    Quote Originally Posted by Speedy_RCW View Post
    Spinning was the only thing that made any sense to me, just could not figure how it was attached to any moving components. Seems very odd that it would help.
  10. #10
    Jul 2015
    Northern California
    1,975
    I noticed a difference when I put it on. You’ll see weird dampeners like that on some vehicles. Kind of like the “dogbone” on mustangs.
Similar Threads
  1. Harmonic damper on T-Case?
    By Ddays in forum Jeep JK Wrangler
    Last Post: 05-16-2019, 07:43 AM
  2. Replies: 10
    Last Post: 02-21-2017, 04:26 PM
  3. Transfer Case
    By super7777 in forum Wanted (Active Members ONLY)
    Last Post: 02-09-2017, 10:19 PM
  4. Transfer case
    By metalic in forum Jeep JK Wrangler
    Last Post: 03-28-2016, 03:26 PM
  5. transfer case oil
    By scout304 in forum Jeep JK Wrangler
    Last Post: 10-30-2014, 06:52 PM
