Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Slight Vibration in Manual Trans after installing rear adams driveshaft
  1. #11
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,712
    Quote Originally Posted by bdubnit View Post
    Thank you guys for the replies! I will definitely remove the front driveshaft and tweak it some more to try and figure it out.
    No problem. Just so that we're clear, it could still be a shaft that's out of balance. Just trying to make sure before you start throwing money at a problem
  2. #12
    Fresh Catch
    Join Date
    Nov 2014
    Location
    United States
    Posts
    22
    So quick update...
    Now that i understand pinion angle a lot more i realized the front driveshaft was likely the main culprit. Disconnected it and the majority of the vibrations went away. Am now getting just a small vibration in second on decel but i think i can attribute that to the rear drive shaft pinion angle.
    The crazy part is I’ve had the front on for a few years but the stock rear driveshaft must have been masking any vibrations.
    Here’s a couple pics showing the rear angles. Just want to double check that this is a good spot to check the pinion’s angle?
  3. #13
    Knows a Thing or Two A.J.'s Avatar
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    939
    No the casting is not flat. You need to measure it on the pinion yolk. It looks a bit high to me but pictures are hard to tell sometimes.
  4. #14
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,712
    As mentioned, you cannot measure pinion from the base of the housing like that. Looking at your pic, your pinion looks high. Rotate your pinion until the top of the u-joint is pointing up. Place a socket on top of it to give you more more room to work with and then place your angle finder on top of it.
  5. #15
    Knows a Thing or Two Samuelh3's Avatar
    Join Date
    Apr 2017
    Location
    Southern California
    Posts
    755
    Tips like this is why I love this forum. Using a socket as a base for my angle finder...genius!
Similar Threads
  1. Replies: 12
    Last Post: 03-22-2019, 01:01 AM
  2. Replies: 8
    Last Post: 07-16-2016, 11:25 PM
  3. Adams 1310 Front Driveshaft Vibration
    By Petzl88 in forum Jeep JK Wrangler
    Last Post: 04-15-2016, 01:42 PM
  4. JKU Slight vibration
    By xflstl in forum Jeep JK Wrangler
    Last Post: 10-22-2013, 02:31 PM
  5. Slight vibration. Looking for help.
    By Team Desert Eagle in forum Jeep JK Wrangler
    Last Post: 07-30-2013, 10:46 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
