Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Stuck in 2nd after axle swap
  1. #21
    Been Around the Block phillypete's Avatar
    Join Date
    Apr 2013
    Location
    Kansas City, MO
    Posts
    318
    Quote Originally Posted by Exodus Jeeps View Post
    This could be the issue, but since he put all the sensors in the rear I’m assuming he went with 52 count rings instead of 60.
    Yes 52 count on the rear.
  2. #22
    Advertiser Exodus Jeeps's Avatar
    Join Date
    Feb 2015
    Location
    Texas
    Posts
    3,300
    Quote Originally Posted by phillypete View Post
    That is exactly what this Artec kit does. I saw nothing in the documentation that it would not work on 2012+ vehicles.
    I’m pretty sure he’s right and most likely this is the issue. You need to run speed sensors at every wheel. It’s not a big deal other than the fact that you already put 52 tooth count rings in the rear already. You’ll either have to change those to 60 count, replace the front unit bearings with the Currie unit bearings built for JK’s, or rebuild your current unit bearings tone ring with the ones Artec sells. You’ll also need abs sensors for a ram pickup.
  3. #23
    Join Date
    May 2016
    Location
    Flagstaff, AZ
    Posts
    51
    Yes, putting all 4 on the rear won't work. There's a ton of info sprinkled around the internet on this regarding the 12+
    If he has the JScan app, he should be able to have different tooth counts front/rear.... I haven't tried this myself, but I saw the option when I bought the app.
  4. #24
    Old Timer Clifford33's Avatar
    Join Date
    Nov 2014
    Location
    California
    Posts
    2,644
    I remember I had a similar problem I was stuck in 4 low because I broke that little plastic bushing for the 4wd linkage cable. Cheap part just a pain to fix.
Similar Threads
  1. Axle Swap on EVO DTD JKU
    By Samuelh3 in forum Jeep JK Wrangler
    Last Post: 01-09-2020, 03:30 AM
  2. Replies: 10
    Last Post: 02-21-2017, 04:26 PM
  3. Axle Swap Help
    By PGH08JK in forum Jeep JK Wrangler
    Last Post: 10-09-2013, 08:44 PM
  4. Axle build or swap it? Help!
    By Hollowpoint515 in forum Jeep JK Wrangler
    Last Post: 07-18-2013, 05:24 PM
  5. Should i do an axle swap?
    By SoCalDozer in forum Jeep JK Wrangler
    Last Post: 06-06-2012, 07:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
