Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Synergy UCA - Rear pinion angle
  1. #1
    Nothing but a Thing RockinAZJK's Avatar
    May 2016
    Waco, Texas
    1,138
    Recently installed a 1350 u joint rear DS and have been running stock rear arms with 4” EVO Plush Rides. With the new drive shaft I needed to rotate my rear axle up to match pinion and DS angle.
    I just installed some Synergy rear UCA’s and now it looks like I need less pinion angle. Catch is that I believe the arms are adjusted all the way in.
    Does anyone have experience with these arms? Are they too long to use with stock lowers or is something wonky with my setup?
    Pic is of the DS v pinion angle with the new arms. About 2* too high on pinion
  2. #2
    Old Timer fiend's Avatar
    May 2017
    SoCal
    3,873
    Quote Originally Posted by RockinAZJK View Post
    Assuming you have the uppers set as short as they’ll go, consider getting either adjustable lower arms or synergy fixed arms, which are 1/2” longer than stock, cheaper than the adjustables, and should correct your issue. I have the adjustable uppers, fixed lowers, and 4.5” springs. All synergy. Can set the pinion properly with that set up.
  3. #3
    May 2016
    Waco, Texas
    1,138
    Quote Originally Posted by fiend View Post
    I was hoping somebody would tell me I was just doing something weird so I wouldn’t have to buy more parts lol
  4. #4
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    8,184
    Ha ha ha ha ha ha ha ha , not have to buy more parts, that’s great!!
  5. #5
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    29,167
    Shorter uppers or longer lowers are the only way to fix your angle.
  6. #6
    May 2017
    SoCal
    3,873
    Sorry.
    Also, that driveshaft looks a bit short to my eye.
  7. #7
    May 2016
    Waco, Texas
    1,138
    Quote Originally Posted by JKbrick View Post
    Hey now! One can hope
    As it would appear 🤦🏼*♂️
    Sorry.
    I sure hope it isn’t. Ordered it from Adams with dimensions and lift specs.
  8. #8
    May 2017
    SoCal
    3,873
    Put it on stands, take the wheels off, and let the axle fully droop. If the shaft separates, you’ll know it’s too short.
  9. #9
    May 2016
    Waco, Texas
    1,138
    Sounds like a next weekend project AFTER I install the new arms I didn’t plan on buying 🤣
  10. #10
    Nothing but a Thing desertrunner's Avatar
    Mar 2013
    Great Falls, MT
    2,149
    Not sure about the synergy arms but I'm running Currie uppers with stock lowers and it works out with my Adams DS but I am 1.5-2" lower than your lift so it's possible the height is just too much to have only adjustable uppers.
    Side note when I ordered my Adams they mentioned how much blue should be showing (can't remember off the top of my head) but mine only have maybe 1" of blue showing at ride height. Might be worth giving them a call and asking about that. Assuming you are at ride height in that picture I agree it looks a bit short
    12' 2dr Gecko Sport 6 speed
    PR44, ARBs, 4.88s, 35 spline rear, Adams 1350 Front & Rear, Rubi T-case, Rubi sway bar + Evo no limits, Evo armor & skids, 37/13.50" Cooper STT Pro, Evo 2" plush / OME med duty springs
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' F150
Similar Threads
  1. pinion angle
    By zj93grand in forum Jeep Cherokee & Grand Cherokee
    Last Post: 02-21-2014, 04:52 AM
  2. Rear pinion angle for JK factory drive shaft?
    By wwood in forum Jeep JK Wrangler
    Last Post: 02-07-2014, 06:38 PM
  3. Rear pinion angle
    By texas05 in forum Jeep JK Wrangler
    Last Post: 12-30-2013, 02:48 PM
  4. Upper vs. Lower Control arms to adjust rear pinion angle?
    By Tumbleweed in forum Jeep JK Wrangler
    Last Post: 10-07-2013, 02:40 PM
  5. Pinion angle?
    By billybob990 in forum Jeep Cherokee & Grand Cherokee
    Last Post: 06-07-2013, 02:05 AM
