Results 1 to 5 of 5
Thread: Manual 1994 Jeep xj HO 5th gear slows down
  1. #1
    Fresh Catch IsraelR's Avatar
    Dec 2019
    California
    3
    So I have a 4.5 lift kit in this running 33Ē x 12.5s. Recently I noticed I start to slow down once I put it in 5th and it takes about 5 minutes for the needle to climb up and get up to speed. Someone told me itís the clutch and that I need to replace itAdjustments.jpg but Iíd like to hear from the experts. Thank you
  2. #2
    Hooked Jeeper125's Avatar
    Jun 2016
    Northern New Jersey
    132
    If the clutch is on its way out the rpms would climb without the car accelerating as fast(clutch slipping), if you are saying that once the jeeps in fifth it takes a while for the speed the match the rpms then I would say itís the clutch is slipping
  3. #3
    Dec 2019
    California
    3
    I havenít seen the rpms act up in that matter, as a matter of fact Iíve noticed climbing a hill on the road has gotten harder.
  4. #4
    Old Timer Snboarder113's Avatar
    Oct 2015
    michigan
    2,718
    5th gear isnít for accelerating anymore when you have big boy tires, mainly coasting downhill... with a tail wind..drafting a semi.
    If this is a new development with no tire /wheel changes than you have something holding it back. Tune up, clogged cat, brake drag etc. As long as your rpms arenít increasing without speed increasing it is most definitely not your clutch.
  5. #5
    Dec 2019
    California
    3
    Thank you so much this definitely helps me to narrow it down!
Similar Threads
  1. Manual tranny: leave it in gear or E brake?
    By vasquez27 in forum Jeep JK Wrangler
    Last Post: 08-14-2019, 01:39 PM
  2. Replies: 13
    Last Post: 12-21-2016, 06:45 AM
  3. Manual trans popping out of 1st gear
    By JeepJeep75 in forum Jeep JK Wrangler
    Last Post: 08-01-2016, 07:11 PM
  4. Correct gear for 37's and manual
    By Diablo in forum Jeep JK Wrangler
    Last Post: 01-20-2016, 11:42 PM
  5. 1994 Jeep ZJ Front Drive Shaft
    By Rubi Freak in forum Wanted
    Last Post: 05-16-2013, 04:59 AM
