Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Thread: Painting powder coat
  1. #11
    Been Around the Block shadowpaige64507's Avatar
    Feb 2015
    United States
    473
    All you need to do is scuff up the surface, wipe down with a rag with some paint thinner then repaint. No need to primer again if no bare metal is showing. We do it everyday here at my work. We have some customers that spec us to paint over the powder for extra coverage.
  2. #12
    Addict jeeeep's Avatar
    Oct 2011
    Tx
    5,645
    I've been spraying the scuff marks on my rails using VHT rollbar.chasis satin black, self priming.
    Only prep I do is wash, unless it's chipped to the metal and then i'll use a small wire wheel in a drill to get the rust off
  3. #13
    Word Ninja Sharkey's Avatar
    Oct 2011
    Nevada
    12,398
    Thanks to all for the comments. Seems like there is some consensus to give the rattle can a shot. I think I'll go in that direction and see what happens. If the first one looks like crap then I'll just get them all recoated.
  4. #14
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    1,753
    Quote Originally Posted by Sharkey View Post
    $150 for five rings.
    Prep in what way (besides light sanding and etch primer)?
    Quote Originally Posted by shadowpaige64507 View Post
    What he said.
    It sounds like you want a good quality finish on them however. So don’t buy Home Depot spray paint. Go to an actual paint supply store that mix automotive finishes and get a base coat and a clear coat in spray cans. It’s more expensive but it’s completely different then “rattle can” and if you want you can match your paint code perfectly.
  5. #15
    Oct 2011
    Nevada
    12,398
    So after all that, I opened the box and the “rash” rings that come with the wheels are thick plastic, not powder coat. Their true beadlock ring is extra. So, I scuffed the plastic, cleaned it, and I’ll see how it paints up.
  6. #16
    Oct 2011
    Tx
    5,645
    I like your paint stands - earth conscience dual purpose use
  7. #17
    Old Timer fiend's Avatar
    May 2017
    SoCal
    3,878
    Quote Originally Posted by jeeeep View Post
    But not saving water.
  8. #18
    Oct 2015
    michigan
    1,753
    Wait they’re plastic? Will that even be strong enough to hold 30psi? This confuses me.
  9. #19
    Been Around the Block Spazbyt's Avatar
    Oct 2015
    St.Peters, MO
    423
    Im thinking the same?
    Quote Originally Posted by Snboarder113 View Post
    Sent from my SM-G960U using WAYALIFE mobile app
    I've never done it but I'm sure i'll be good at it
  10. #20
    Nothing but a Thing jdofmemi's Avatar
    Mar 2018
    Menifee CA
    2,289
    Those are fake rings. The tire mounts to a bead, like a normal wheel, then the ring is for looks.
    Some wheels like this are dual use, and can be used with a real ring and the bead on the outside to make it a true beadlock
Similar Threads
  1. Powder coat issues
    By Chris1015 in forum Jeep JK Wrangler
    Last Post: 04-03-2017, 02:13 AM
  2. Pre powder coat seam sealer
    By Lexiewalker in forum Jeep JK Wrangler
    Last Post: 09-12-2016, 10:56 PM
  3. Textured powder coat touch up?
    By DWiggles in forum LoD
    Last Post: 05-08-2016, 07:01 PM
  4. Matching Powder coat
    By 5280Sapper in forum Jeep JK Wrangler
    Last Post: 04-08-2016, 09:28 PM
  5. PSC Bumper... Rattle can or powder coat?
    By JK'AJUN in forum Jeep JK Wrangler
    Last Post: 07-12-2013, 06:38 AM
