That’s a hell of a find! Can’t help on the install, but looking forward to seeing if it works out.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Anyone done it themselves? I lucked into a great deal on the entire set up out of low mileage running Jeep. 5.7vvt Hemi with 545rfe trans and Rubicon transfer case along with all the conversion parts except motor mounts and battery tray. Seems like it shouldn't be too bad. Most of the tricky stuff is already done. I would like to hear from any of you that have actually done it. Problems that arose, things you might change and or improvements that could be done easier prior to install. Thanks in advance!
2015 JKUR AEV JK350
1985 CJ8 Scrambler
2015 JKU Rubicon AEV JK350
1985 Jeep CJ8 Scrambler
I’ve done a few. What year are you putting it into? Reason I ask is the 5.7 isn’t much of a gain over the 3.6, it is a noticeable difference over the 3.8 though. Always regret not just doing a 6.4.
Not "living" but "loving" life always!
Going in a 2011 which is the 3.8 should be a big improvement. I had plans to go LS or Hemi at some point anyway I just didn't think it would be this soon. I just moved up to 1 tons this year so I'm good to go there. I just want to make sure I have a reliable solid setup when I'm done. I drive it everywhere. No trailer. Any advice is appreciated. My little 3.8 has been super reliable. 90k on it with no problems at all.
Me too! Just lucked out on the deal.
Now I just have to figure out how to get all this in the Jeep. Might be a little more than the normal weekend project.
Just a bit! Looks massive
2015 JKUR AEV JK350
1985 CJ8 Scrambler
That’s what she said
Great find man...and good luck with the install...
