2014 Jk won’t start
Gadget
Drove once this morning, got home. Went back out about 1/2 hour later. It will start and run for maybe 3 seconds then dies. Any ideas?
Sent from my iPad using WAYALIFE
2nd.gunman
Guess it could be a cam/crank sensor as well. Engine fires, doesn't get a running reading and stops sending spark to the coils. It really needs to be hooked up to a scanner to see what's going on when it fires.
Usually cam/crank sensor failure will stop it from starting not from staying running. Not 100% familiar with the 3.6 but that has been my experience with other engines
Does it start then turn off. Or does it start then sputter itself out.
If it’s shutting itself off it’s security.
nbunga
This
There’s a little red light with no label on the right side of the dash, above the temp gauge, that’s for your security system. Is that coming on before it shuts down? I don’t think you can even tell there’s a light there unless it’s on.
Noble Woodsman
The crankshaft position sensor (i think that's the one - it's on the bell housing) will shut down a running engine when the sensor fails, because the computer can't figure out the timing. This usually happens when the sensor is warmed up, and can be tricky to reproduce. If the engine starts and runs after sitting overnight, it could be this sensor. Otherwise, if you can reproduce the 3 second shut down on a cold engine, I agree that it's probably the key fob or security. I would try your second key if you have one or replace the key fob battery.
cozdude
Guy with a Red 2-Door
Without knowing what codes you have it sounds like an immobilizer (key/security) issue to me. This is just pure speculation that without a code to help point you in the right direction
Texas Nick
Like everyone else said. If you see a blinking red light above your temp gauge. It’s the security system and will have to use your spare or buy a new key. Mine was so worn it wasn’t reading it anymore and would shut it off right after turning it on every time.
Gadget
The little red light did come on, I don’t have a key fob just a regular ole key. Disconnected the battery for about 15 minutes, reconnected and it started fine, been good ever since.
