KeroJK
Hey guys, the other day I noticed a leak on the bell housing where the transmission mounts to the engine. I read up and looked into it some more, suspected it was the upper oil pan gasket, I replaced it with a new gasket the other day, cleaned everything up, and it's still there!
There doesn't seem to be any oil coming down to that spot, rather it's coming from between the bell housing and the dust cover. I have no clue at this point and am looking for some suggestions on where I should look next before I go to a shop.
Below I have attached pictures of the bell housing and as far up as I can see to the sides. Also the valve covers which don't seem to be leaking and this random spot that I saw a little "wetness" around.
All your help is appreciated as usual! Thank you! View attachment 344836 View attachment 344837 View attachment 344838
Sent from my GM1925 using Tapatalk
