What makes them so different that they do not require a break-in process?
They are machined like oem gears in a new car, have you ever seen a new car that must go to the dealership and have the gears checked and fluid changed after 500 miles. It’s also like the UD60 axles they don’t require the initial 500 mile fluid change either. It’s an extra step in the process they do. Below will help explain it. It’s the lapping that eliminates that process.
Face Hobbing
Cuts gearing to precision spacing between gear teeth
Ensures continuous indexing so teeth are constantly mated
Significantly reduces noise, vibration, and harshness
Lapping
Removes tool cutter marks from tooth contact area
Reduces noise and heat
Produces a better contact pattern
