Any of the suspension systems from evo can handle 40's. the bolt on coilovers are no exception. On a 4 door there are a few things that you will need to run the suspension system. At minimum you will need adjustable front lowers control arms, a new 1310 or 1350 driveshaft(it will be a narrower diameter to clear exhaust), and preferably the evo drag link flip kit to relocate the front trackbar up and correct the steering. You will most likely need spacers to clear the tires. If you will be running stock axles you will want to reinforce the c's with evo c gussets. 40's are big and very taxing on the stock axles and steering. most do major upgrades to run them properly and with confidence like bigger axles, ram assist steering, ball joints, etc. all of those upgrades are rec but not required like the parts mentioned earlier. Ymmv.
Good luck.
