TIPM issues!!! Has anyone replaced??
jeeeep
Changed plugs 20 k miles ago. Coils are original and not throwing a check engine light
Only happens after I’ve been driving for 40 min or longer
did you also change the PCV valve and did you check the O2 sensors?
I had to take my JK to an automotive shop to find out O2 sensor was bad, no check engine light or codes
Ny in az
Thought it was the fuel pressure relay inside the TIPM but it turned out to be the crank position sensor that was dropping off intermittently and once we replaced it we’re all good. Thx for the suggestions!!!
