Long arm brackets.
Clearskies
So.. last year I upgraded to EVO's high clearance long arms.. I've been very happy but I've found a bit of an issue. I've had on both sides now the lower front bracket fold over into the joint.
I haven't contacted ORE yet, I'll do that Monday but I'm curious if anyone else has the issue.
fiend
Um Don, It’s because you wheeled your Jeep. On the Dusy Ershim trail. Shit happens. 🤣
Clearskies
Still.. a little redesign should fix the issue. Its not a big deal, ill cut off the bottom on that tab but EVO could make it more robust..
Um Don, It’s because you wheeled your Jeep. On the Dusy Ershim trail. Shit happens. [emoji1787]
jdofmemi
Looks like they need to be boxed in with a skidplate of their own.
They also look to be a little thin. The control arm mounts on my Fusion axles looks to be a fair amount thicker than those.
Clearskies
I think they are thin for what they are trying to do. Clearly they are thin since they folded over.... I'm really not very hard on my stuff.
Even if they had some gussetting to the side it would help.
