ProRock 44 Track Bar Hole Oval’ed Slop
aermotor
ProRock 44 Track Bar Hole Oval’ed Slop — FIXED!
Have gotten some death wobble in the last week so took things apart to investigate, turns out the axle side bracket holes on my ProRock 44 are oval'ed out. Looking for opinions on a solid fix. I've seen people say weld on washers but I question if that's enough? Dynatrac HD BallJoints are still solid. Tires are balanced.
ETA: Update below with fixed solution.
Thanks!
fiend
You need to fix that slop. Welding on some washers is probably the easiest fix. Filling the holes and re-redrilling is another, but more work.
Thanks!
Damn, even with that thick bracket. That’s impressive.
When my stock tin foil track bar bracket got wallowed out worse than that, I drilled a hole in a little piece of 1/4” plate and welded the plate over the existing bracket. Worked well. Like Fiend said, plugging and redrilling would be the best bet, but more work. I’m sure the brackets are mild steel...therefore no problem plugging with mig wire. Of course it will be harder steel to have to drill through. But definitely possible with the right drill. I digress...good luck.
JKbrick
Thanks!
Was the bolt loose or something?
kyle521
This happens from the bolt being loose rather than a fault in the bracket. Quick fix is welding on washers
bmkrinne
OEM track bar bolt is an M14 and slightly loose in the Dynatrac bracket holes. Mine was moving as well and caught it after about a 500 miles on my PR44. I measured the holes and a 9/16” bolt fit quite a bit better and tightened everything up.
Sucks yours got wallowed out. By the way, check the frame side also as mine was slightly egged there as well. 9/16” bolt tightened it up.
BlueRubicon
9/16" bolt fit through track bar then I presume?
aermotor
Bolt was not or ever loose, no. I've beaten on this thing pretty good over 50K miles. Have always had a 9/16 bolt since I got the PR44.
I didn't like the idea of just a standard washer so I ended up buying some stepped washers from Kartek—no affiliation just found them through google. Amazing product. It adds roughly 3/8" to both sides giving a huge amount of support and strength. I'm also getting the Synergy frame bracket to help with that side.
Step 1: Make template in scrap piece
Step 2: Clamp to track bar bracket
Step 3: Drill out 1" hole both sides
Step 4: Fit stepped washer
Step 5: Weld in
Really happy with how it turned out.
