Results 1 to 10 of 10
Thread: Dynatrac Hard Core Plus XD60/XD60 Wheel Question
  1. #1
    Fresh Catch
    Join Date
    Sep 2014
    Location
    United States
    Posts
    5
    Question Dynatrac Hard Core Plus XD60/XD60 Wheel Question
    Currently, Im running a RK Pro-X 3.0 Kit on 37X12.50 Ridge Grapplers with 17X9 wheels that have a 4.5 bs (suggested bs by RK but I wish they were tucked even further). I have a set of 68.5" wide XD60s on order and live in PA so I need to keep my tires tucked in as reasonably as I can. I've seen guys running 5.5 bs to keep the scrub radius minimal and to tuck the axle ends further inside the wheel for added protection and clearance. Since the XD60s are 68.5", my understanding is they will push the tires out another 1/4" on both sides vs stock so I should go to a 4.75 bs wheel to retain the stance of my current setup.
    My question is, do the 1550 knuckles allow a larger offset of 5.5 bs even though RK recommends a 4.5 bs on a stock axle? I will be running Trail Ready HD17s which are 8.5 wide. They can make whatever bs you need so that's a none issue. Im just not sure if 5.5 bs will cause any issues? Im also wondering if a 5.5 bs will cause the lock out hubs to stick out to far causing them to get beat up when out on a trail.
    Is there anyone that can help provide me some guidance? Thanks!
  2. #2
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    6,596
    Quote Originally Posted by hellcat707 View Post
    I'd contact Dynatrac. I'm sure they could help you out.
  3. #3
    Fresh Catch
    Join Date
    Sep 2014
    Location
    United States
    Posts
    5
    Quote Originally Posted by jesse3638 View Post
    I contacted Dynatrac and they said they couldn't say based on the many variables.
  4. #4
    Nothing but a Thing RESURECTIONJK's Avatar
    Join Date
    Oct 2016
    Location
    SALT LAKE CITY, UTAH
    Posts
    2,049
    Eddie was running 5.5 bs on Rubicat with the 72.5” XD60. Go back and watch the video he did on it and that may help. Also if you’re running the RK tie rod and drag link then that MIGHT be more of an issue than the knuckles themselves. Not sure if that is your steering setup but, it’s worth noting in case you are.
  5. #5
    Fresh Catch
    Join Date
    Sep 2014
    Location
    United States
    Posts
    5
    Quote Originally Posted by RESURECTIONJK View Post
    His video was what originally got me thinking about 5.5 bs. in the adjoining post he stated "That being said, if you like a factory look, prefer to have your fenders cover your tires or need to because of state laws, going with a standard 68.5" width will get the same job done so long as you aren't running a coil over kit like the EVO DTD".
    He also showed Dynatracs JK beside his which was using the 68.5" axle which is exactly the stance Im looking for. They were both running 13.50 tires on Trail Ready wheels while I will be using 12.50s so they would be pulled in slightly more. With so many differences between the JK & JL/JT Im not sure if that post/video still applies. It would be fantastic if it did!
  6. #6
    Addict Brute's Avatar
    Join Date
    Nov 2015
    Location
    Mainland
    Posts
    9,365
    I have the XD60 72.5” with 5.5 backspace on my Brute...I went with the wider axle because of coilovers...and yes, the locking hubs stick out from your wheels, which prompted me to go with wider rock rings on my Trailready beadlocks, which helps a little...
  7. #7
    Nothing but a Thing A.J.'s Avatar
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    1,191
    With the 68.5 axles and 37’s 4.5” backspacing will be just right. 5.5” back will be too much you will probably rub on the frame at full turn.
  8. #8
    Fresh Catch
    Join Date
    Sep 2014
    Location
    United States
    Posts
    5
    Quote Originally Posted by A.J. View Post
    I appreciate the info!
  9. #9
    Advertiser Exodus 4x4's Avatar
    Join Date
    Feb 2015
    Location
    Texas
    Posts
    3,557
    Accurate
  10. #10
    Fresh Catch
    Join Date
    Sep 2014
    Location
    United States
    Posts
    5
    Quote Originally Posted by Exodus 4x4 View Post
    Accurate
    Thank for confirming! Looks like I know what I need to do.
Similar Threads
  1. Dynatrac ProFloat XD60™ Axle
    By jorgelrod in forum General Jeep Stuff
    Last Post: 01-28-2020, 10:50 PM
  2. Dynatrac Elite ProRock XD60 Calipers
    By bhaner in forum Dynatrac
    Last Post: 01-02-2019, 07:26 PM
  3. Replies: 36
    Last Post: 12-19-2017, 01:51 PM
  4. Dynatrac xd60 parts help
    By salty_jk in forum Jeep JK Wrangler
    Last Post: 04-25-2017, 04:40 PM
  5. XD60 swap wheel backspace
    By PATRIOTKJM in forum Jeep JK Wrangler
    Last Post: 01-10-2017, 06:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
