Page 138 of 144 FirstFirst ... 3888128136137138139140 ... LastLast
Results 1,371 to 1,380 of 1439
Thread: Enforcers Unite!
  1. #1371
    Advertiser Exodus 4x4's Avatar
    Feb 2015
    Texas
    3,537
    Quote Originally Posted by HighwayTrout View Post
    Was only a block away from a dealer so I stopped in to see if they had one.
    245 bucks later...
    Attachment 334526.
    Getting sick of chasing these little bumps, squeaks and rattles. One part at a time.
    Damn dude, if you’re gonna drop that much money on a track bar why not get a Synergy?
  2. #1372
    Sep 2019
    NoVA
    74
    245 bucks later...
    Attachment 334526.
    You're on the wrong side of the country from me, I have one up on Craigslist (for next to nothing) that I'd just give you, if you were closer.
    Sent from my SM-G965U using Tapatalk
  3. #1373
    Old Timer HighwayTrout's Avatar
    Dec 2013
    California
    3,986
    Quote Originally Posted by Exodus Jeeps View Post
    Next time for sure. Buying connivence is all it was. Not the first time and probably won’t be the last that I get boned from a dealership.
    Quote Originally Posted by '18 WIllysW View Post
    Thanks. Hopefully someone local to you can use it.
    en hopup veritas
  4. #1374
    Fresh Catch
    May 2013
    Kirkland, WA
    6
    Slowly making progress with the install. Another noob question - what do you folks do with the xmas tree clips that hold the ABS harness in the rear? On each side there are two that attach to the frame and two that attach to the control arm bracket. I had to pop a few of them off to drop the axle low enough to get the springs in, and now I am inclined to leave one of the frame ones off so that there is still more slack now that the the springs and new shocks are in.Jeep_ABS_Harness.jpg
  5. #1375
    Been Around the Block jjlong's Avatar
    Apr 2015
    SoCal
    471
    Quote Originally Posted by donracer View Post
    I left mine off and ended up pinching the wire on something. Caused all kinds of ABS problems. But, maybe that was just my bad luck.
    Sent from my SM-G960U using WAYALIFE mobile app
  6. #1376
    Nothing but a Thing -AINOKEA-'s Avatar
    Oct 2011
    Hilo, HI
    1,100
    Here’s a friendly reminder to keep your Johnny joints greased properly... I’ve had a suspension noise that sounded like crap going over speed bumps. Thought it was the shocks as they’re getting pretty old. I’m pretty sure I found the culprit though. Fortunately I’m pulling the front lowers to rebuild them now and start fresh. Here’s a vid with what it sounds like. Both lowers sound like this, not just the one I blew out.
    https://youtu.be/rVVMTLoY06A
  7. #1377
    Fresh Catch
    Aug 2019
    League City
    5
    Just joined the Enforcer Club!
    3’ with drag flip, Rancho 9k’s and Saltas on 35’ Toyo’s. Added a 1350 and C gussets up front. Couldn’t be more happy with the ride. Reading all of your comments for the last couple of months paid off huge dividends.
    Attached Images Attached Images
  8. #1378
    Oct 2011
    Hilo, HI
    1,100
    Quote Originally Posted by FourEyedFox View Post
    Nice! Congrats!
  9. #1379
    Nothing but a Thing TOPLESS's Avatar
    Mar 2015
    Benton Harbor, Michigan
    1,664
    Looks good man!
  10. #1380
    Fresh Catch
    May 2013
    Kirkland, WA
    6
    Self-tapping bolts for bump stops
    Any tips on getting the self-tapping bolts going? I drilled a 5/16 hole, but have been having a hard time getting the bolt in. I am tempted to try to enlarge to 11/32 (but didn't have a bit of that size yesterday). Or should I consider getting a 3/8 tap and tapping the hole with the tap rather than the self-tapping bolt?
