Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: External hard drive help...
  1. #1
    Caught the Bug NETAAA's Avatar
    Join Date
    Apr 2013
    Location
    Pomona, CA
    Posts
    50
    I have a maxtor external hard drive that somehow got a virus, I took it to my computer guy that usually fixes all my computers. He told me that he couldn't even get to the files, that I would need to take it to a "specialist"
    I took it to a local shop with no luck. I really want to get all my kids pictures that I have saved, anyone have any recommendations, leads, info.. I got this thing to protect all my pics, and this happens!! Help!
    Thanks in advance fellow jeepers!
    Eric
  2. #2
    Nothing but a Thing pastorwug's Avatar
    Join Date
    Oct 2011
    Location
    California
    Posts
    1,691
    There's a great company called "Drive Savers", they have been able to recover files even from drives that have been through fires.
    2011 JKU Stone White Rubicon
    Chazak ve Amatz! חֲזַ֖ק וֶאֱמָ֑ץ Be Strong & Courageous! Joshua 1:6
    "praesis ut prosis ne ut imperes"
  3. #3
    Join Date
    May 2013
    Location
    Davenport Iowa
    Posts
    129
    Is it just a virus or is the drive failing too?
    If its just a virus you can order a USB to IDE/sata cable and attach it to a pc to run all the virus scans.
    My normal free scan process is
    Malware bytes
    Combofix
    Avg antivirus
    I've had this remove dozens of viruses through my work
    If the drive is failing, while it might sound odd, put it in a freezer bag and the freezer for a few hours. I've had it save a handful of failing hard drives over the years. It's only a temp fix and usually allows the drive to boot up for 30-45 minutes.
  4. #4
    Nothing but a Thing pvanweelden's Avatar
    Join Date
    Apr 2013
    Location
    Des Moines
    Posts
    2,034
    I am a sys admin, and I would do exactly as Masjk just said above
    Sent from my LG-C800 using WAYALIFE mobile app
  5. #5
    Join Date
    Apr 2013
    Location
    Pomona, CA
    Posts
    50
    Well it's drive failure too.. The last guy took it all apart so I have all the pcs in a bag...
  6. #6
    Join Date
    Apr 2013
    Location
    Pomona, CA
    Posts
    50
    Quote Originally Posted by pastorwug View Post
    Thanks ill give them a try if all fails..
  7. #7
    Been Around the Block GuillaumeC91's Avatar
    Join Date
    Apr 2013
    Location
    Ottawa, ON
    Posts
    399
    Quote Originally Posted by NETAAA View Post
    If the parts are all in a bag, then let's hope the guy knew what he was doing because a simple virus would of been way easy to remove from the drive. An external drive isn't like your computers drive. Its hard for most virus to run of something that is not OS based.
    If the drive is apart, I'd suspect the arm motor or the plate readers themselves. In that case, the disks themselves should still be good and still be holding your data. The fix? Find the exact same drive (with working arm and reader), take it apart and swap disks. That's what most data recovery shops are going to do. If the disks were corrupted, then a FAT or NTFS scanning software can rebuild the sectors back with correct data, but in some cases a small percentage of the data can be lost if it was overwritten.
    Good luck!
  8. #8
    Join Date
    Apr 2013
    Location
    Pomona, CA
    Posts
    50
    Quote Originally Posted by GuillaumeC91 View Post
    Good luck!
    Thanks for The replies guys, I'll take a pic of all the parts I have just to give you an idea.. Now that I remember, the problem with the drive wasn't a virus it was malfunctioning.. Sometimes when I would connect it, the computer couldn't read it but after disconnecting and connecting it back it would... After some time though, nothing I did made the computer read it. Even on my laptop.
  9. #9
    Join Date
    Apr 2013
    Location
    Pomona, CA
    Posts
    50
    This is what I have left.. Can I buy smthg to connect to it how it is now, and try to fix? Or do I just try to find a company to do it?
  10. #10
    Join Date
    May 2013
    Location
    Davenport Iowa
    Posts
    129
    I'm on my phone so can't read to much on the cable. But this should be what you need.
    http://m.bestbuy.com/m/e/product/det...d=mp1307116937
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
