Update on the CJ-3A. It wouldn't start and had no spark. Started looking around and found the alternator wire to the battery fried. It runs through a ammeter first. Also found some other questionable wires.
I pulled the alternator to have it tested and it passed with flying colors. After that the jeep still refused to start and kept blowing a fuse. The ignition switch in the GM column was sketchy at best so I bought a new one. That fixed my short but still no spark. I had power to my coil but nothing from the distributor. From there I inspected the cap/rotor and verified continuity through all my wires. I replaced the coil and still no luck. The Willys has an aftermarket Mallory ignition with coil, control box and distributor. They are no longer in business so parts are harder to come by.
This is where I decided to upgrade to HEI. Everything is integrated into the distributor and it's a one wire hook up.
It's has a much bigger cap and trimming the firewall was required to drop it in the block. The cap is so big that it won't work with my Holley double pumper carburetor. This meant I had to go with a Edelbrock setup to get the clearance required. Found a 600 CFM on CL for $50.
A 4 BBL carb it too big I feel and a two barrel would be better. But it ran pretty well on the 540CFM Holley so it will be alright for now. I'll have to wait until next week to hook everything up.
Sent from my iPhone using
WAYALIFE mobile app
