Looking like Vince had some pics. View attachment 357855 View attachment 357856 View attachment 357857 View attachment 357858 View attachment 357859
Nice Jerry!
Well after this trail and the NY’s Run, I started hearing a bearing noise as I drove home, so I figured I’d better drain the oil in my rear differential and take a peek and this is what I found:
So I pull the cover and find this:
But, I had a great time on the trail and was able to drive home for 7 hours on my own!
Vic
Vic
Vic
Time for 60s ?
And looks like this plug weld is breaking loose. Should I grind it out and weld it up?
The important weld is the plug to the tube, which I gather is intact. The housing is cast, so it’s tricky to weld. Is there any oil seapage between the housing and tube?
Those that were on the trail know that I had an air compressor issue the first time I turned on the lockers. With the lockers off and the compressor on I had a big air leak that we were unable to locate on the trail.
Today I pulled the passenger seat and took a closer look.
What I found was air leaking out of the pressure relief valves on the compressor.
Not sure what is going on. Could be the pressure switch. Could be an overheat issue. I did notice the fan is not running.
I sent a message to ARB to see what my options are.
Thats funny, it seemed to improve tightening that fitting on the trail, I figured it just needed a more thorough going over tighting fittings.
I didn't know there's a relief valve. Is that on the pump or manifold? Is the pump running on the side that the fan's not running? Did you check the fuses?
Two relief valves. One on each motor/pump. Both pumps seem to be running and making air. It gets up to pressure and then the valves open and start dumping air. Makes me think the pressure switch could be letting it make more pressure than it needs.
There only seems to be one fan. It is in the center with the relays and pressure switch.
I haven’t found a blown fuse yet. The little fan always came on with the compressor switch. That part works. The fan just doesn’t spin.
