Anyone have the LOD Destroyer Rear Bumper w/ Tire Carrier?
gheller
Thanks Erin for the info and pics. Looks good, andnof course that bumper looks great.
I don't know why they would have to make the installation so involved when many other aftermarket bumpers just bolt right up to the original mounting.
aermid
Sure thing, and thanks. It seems like a really solid bumper. The directions aren't too bad. I think most of it is just my inexperience, but I would definitely follow the online version of the install manual. I think my print copy was a little old, but the online version seems on point.
drrty_jk
Awesome. I ordered one of these in November.
How long did you guys wait for your order to ship? Hoping mine will ship soon.
Edwrds
Got the first half installed last night. Finished around 2am. Lots of mistakes by us; this was our first bumper :).
Things that we found out the directions sorta glossed over:
The side cross-member holes gotta be drilled inside and out; we dry fit to double check the directions "3/8" distance. That was spot on so could have saved a lot of time not doing that. The directions say 5/8 holes; don't short change that else the bottom cross member bolts will be hell.
To help hold it and level it we used a normal tire changing jack. I don't have a high jack yet; I'm sure that would have helped or a floor jack. Jack stands weren't accurate enough imo to help level. Also I ended up hooking tie downs from the toe points to the roll cage to help front-to-back to get in line with the body (I just eye balled that direction). I used a 3ft level going driver/passenger.
Do NOT tighten down anything till all 10 of the bolts are in; found that out the hard way :)
The washers are huge and will overlap. Looks like that's same as in their direction pictures.
The bolts seem short but after tightening everything down; seemed like there was enough bite.
No idea what the 4.5" bolts are for yet; going to call them this morning.
I started mine then found out that you have to install the lights before you install the bumper. LOD said you can drill the holes with just the two stock bolts in on both sides? Just received my lights so going to install the bumper tomorrow will let you know how it goes. Your right the online directions are way better than the prints. The middle holes were easy to drill.
aermid
Good luck. We got it all together before the trip but I think we are going to have to level it more front-to-back. The carrier arm ended up being just a little off from flush. I was able to use a thinner bolt on the top rubber bumper to make it flush but it sways out a little on its own. This is something we will have to go back and correct. We measured a few times on both sides and middle to try and get it right. It has to be flush when closed. If it doesn't fit exactly in the latch it will be noisy. Once I fix it, it's been silent.
Edwrds
Guess I'll let you know how it went. Really don't look forward to messing with it. Hope I have better luck.
Thanks for the info.
NotInStock
Well, I ordered mine back on the 16th of December so hopefully I will see it in another couple weeks. Any advice anyone has on installing it is very much appreciated... I am doing a ton of upgrades at this time and my poor jeep has been half disassembled in my garage the last 2+ weeks... But I should have it back on the road this weekend needing an alignment though...
Mybadjk
Don't have their destroyer bumper. But have their version 2 of their old tire carrier and it has held up great and is very stout. Comes well packaged as well.
eazy
I ordered mine on December 13th. They didn't respond to any of my emails or private messages for a status update so I gave them a call today. They said they expect it to ship next week.
Sent from my Nexus 6P using WAYALIFE mobile app
CJKU
I had a similar experience, they outsourced their powder coating to a third party and it took me a few weeks to get mine. They did miss a few small spots, so keep an eye out for rust and touch it up with some black paint. Otherwise, nice bumpers...
Phaetonman7
Mine is supposed to be here Tuesday. I ordered it on cyber Monday 11-28-16. It was a Christmas present for my wife's jeep that didn't make it here in time.
Leeboy03
I don't have it mounted yet or painted either. As far as the welds go, it's not that they are necessarily bad, just don't look as good as evo, and some of the other manufacturers. Welds were run hot and have a lot of undercutting. Hoping the spray on bedliner covers it up!
