What's in your Jeep tool kit?
Thanks I’ll study what you’ve got. This last summer I had to turn around 4 times for 18-24” trees down. Small ones I’ve been able to winch out of the way, or just go over if their on the ground. My regular Stihl is just too big for a camping/Jeeping trip.
It's a Craftsman 46cc 18" . I only have one old picture of it in my Jeep but I still carry it in about the same way. By putting the case with saw blade toward the rear, a lot of stuff can still be stacked around it.
aTX427
Sorry if this has been talked about, but I think I want to start carrying a chainsaw with me, but they take up so much room. Anyone else carry one? Have you found one that’s easy to stow away?
I have a battery powered one from when I used to overland. Went on a trip that called for one, purchased it when I came home and haven't needed it since. Still new / unused if you are interested.
JKbrick
Probably wouldn’t be as good as a chainsaw but you could get a Milwaukee sawzall tool only to match your other tool there and get some long wood blades. It would work for smaller trees too
wjtstudios
That electric Stihl is interesting. It could help clear a decent sized tree of a trail with out keeping a gas smelling chainsaw inside the jeep with you. It wouldn’t help you clear the Mackenzie, but for and occasional tree, it might be a nice piece of kit to carry.
I actually have that setup already too, lol. Turns out this corded Milwaukee tool was just in there for a few days while I was helping a buddy. This thing just crapped out on me after about 10 years of hard use. I used it for cutting a ton of steel over the years. I'll definitely be getting another one. It's a great tool.
Maybe the Perfect tool bag for my Jeep
Howdy, I just bought myself a birthday present, the Yorktown tool roll bag from Atlas 46, a company based in Missouri. It looks great from the videos. I love the idea of small pouches to hold the different types of tools and the incorporated wrench roll bag.
Website is www.Atlas46.com the bag I like is here https://www.atlas46.com/products.html#!/Yorktown-Tool-Roll/p/88260008/category=14466133
Its not cheap but I thought some of you guys would appreciate the design and its "made in the greatest country in the world". Their words but I would agree. I have no affiliation with them but wanted to share. I have no experience with the company so I'll wait till it shows up to confirm. They could use a little of Eddies help with the editing and this bag is backordered but they are making a new batch.
Cheers.
Jackal01
Exodus Jeeps has these for sale for those that want to support a forum vendor.
Exodus 4x4
Cheers.
Yep. We have 4 of them in stock if anyone’s interested. Yes they are pricy but extremely well made.
I-Eat-Mud
I think all of this has probably been covered... And some of this stuff won't be relevant to most people. There's also a couple items i only grab for going to certain locations. But here's my list.
General stuff
Fire Extinguisher
Tool bag
Compressor
spares kit
First Aid Kit
fluids kit
Water
food
jacket
Recovery bag
snatch strap
sunscreen
bug spray
Tarp
Bivy
Bottle Jack
tire patch kit
Shovel
Flashlight
CB
Jumper Cables
Paracord
Tools
Lug Key
hatchet/axe
gloves
multiple ratchet straps
bottle jack
4x4 block
BFH
pry bar
lug wrench
2 Cresent Wrench
2 Vice grips
Small flathead
Large flathead
Small philips
Large philips
Channel locks
needle nose
long needle nose
standard pliers
files
Bailing wire
Duct tape
electrical tape
Zip ties
breaker bars
Socket adapters (1/2 to whatever)
torx set
allen set
wrench set
socket set
1 5/16th socket
35mm socket
1/18th socket
volt meter
2 tire spoons
JB weld
small tape measure
Wire Crimper
razor
Center Punch
2 C Clamps
Pickle Fork
Crimp Ring Pliers
Magnet
Impact
Sawzall
Recovery gear
Snatch block
Snatch strap
winch remote
D rings
high-lift
Tree Saver
Large ratchet straps
small ratchet straps
Spares
Spark Plugs
2 1350 U joints (drive shafts)
1 1550 U joint (axle shafts)
hose clamps
fuses
Break Line
Serpentine belt
Gasket maker tube
Ball joints ?? (I have this marked because I want to get a spare pair to live in my spares kit)
Nuts and bolts ?? (I want to expand this out and inventory what I have, its just a bag of bolts and stuff)
Caps for hydro steer
spare wire
wire connectors
Fluids
Power steering
break dot3
Coolant
Diff fluid
Ether
Wd40
Grease
I'd really like to add a trail welding kit, and I wish I had room for some more spares.
OverlanderJK
Resident Smartass
With all the talk of torque wrenches the last few days and me having to buy some new stuff from theft I figured I would bump this.
This is minus sockets, spare parts and some other stuff that were stolen or not here for the pictures.
All laid out
Electrical and u-joints
Traps, zip ties and pump
Recovery gear minus winch control with is on the cage
Bottle jack, c-clamp and sledge
Torque wrench, screwdrivers, gloves and breaker bar
Tool rolls
Nuts/bolts, tire patch kit
And all under the deck packed up
Mybadjk
All laid out
Tool rolls
Great idea for the nuts and bolts. You put the bottle jack in the tool bag? Nice idea as well.
notnalc68
That dude from Mississippi
All laid out
Tool rolls
I need to off road with you, then I won’t have to carry anything.
Brute
Nice tire patch kit.
It would be a shame if someone used it to cut into your soft top and steal stuff.
Actually some idiot did cut into his soft top last January during the Lucerne Valley run...I think someone was trying to relieve him of his fridge...
