NEW!!!! 2" SPORT system with progressive coils front and rear!
WiscoHR
So, I've had this suspension for 2 months now and must say I'm still happy with the ride. But the front springs have settled a little bit. If I run the 9000s at setting 1 it will get into the bump stops on any significant bump on the highway. Thinking about either adding a small spring spacer to the front or getting shorter bump stop extensions. All figure all that out after I get my new tires here shortly.
Sharkey
Word Ninja
Still waiting for mine to show up from QTec. Sounds like it could be another couple of weeks. Anyway, did you do anything with the bump stops? I'm just wondering if I should plan for the sag and do something right out of the gate.
Rancho
It comes with the stops for the front. That is where the "concern" is from our standpoint.
Sharkey
Word Ninja
Thanks, I saw that. :thumb: Sounds like the guy above is hitting them pretty quickly. I'm just wondering if I should go with less of an extension.
Rancho
Just seeing this!
Call our Tech line and let them know please.
They can be reached at 734-384-7804.
Monday AM are a bit rough FYI.
Just saw this (or that). I say run it. I know a guy :)
(Who knows a phone number Ha!! )
WiscoHR
Just seeing this!
I'll give them a call tomorrow and see what I can figure out. Also I'll post up a coupe of pics of what I'm seeing then.
Sharkey
Word Ninja
Let me know what they tell you. I'd like to cut this off at the pass if possible.
WiscoHR
Here are a couple quick pics. In the first you can see where the bumpstop has cleaned the dirt off from contact. There is about 1 inch between the bump and extensions. The top 3 loops of the coil are completely compressed and touching.
Sharkey
Word Ninja
Thank you Rancho (Matt) for help getting QTec moving. I'll post up pics in the daylight when the Shark Tank is all buttoned up.
enfielded0405
So if I was looking to put 35's on a 2 door with stock fenders would I be good to run these and a 1" spacer front and rear? Curious if I would need new driveshafts or adjustable control arms for that height.
kcroyals1738
Mine is a bit different since I have a 4-door, but I have this kit and KO2 315s and haven't had any issues with my stock fenders. Rides great and as of now I don't think it needs any other mods. I haven't gone off road yet so I might trim the fenders soon, but just as my DD it has been great so far. No rubbing yet even when I went looking for some so far.
BaddestCross
It depends on if this system gives a true 2" on a 2 door. I used EVO springs in the front and got 3" out of them once the settled in, so no spacer needed for 35s.
That said, you're gonna want to swap out your driveshaft eventually because it will catch on the exhaust skid and tear the boot. You won't need adjustable arms yet. I do recommend C gussets, though.
[Sent from the WAYALIFE mobile app]
Clutch
You probably won't need a new driveshaft unless you put on new shocks that extend past 25".
