Rear Brake Wear
JoeB-JKURX
Just had gears installed and installer tells me that my rear brake pads are almost worn out. I've only got 40K on the Jeep and the fronts are in good shape. From my previous experience with brakes, it is usually the fronts that give up (replaced at least once before the rears needed attention). Is there a reason (braking system) for the rears to go early on the JK?
ammojustin
That is strange! Do you feel the brakes dragging you to a stop or more of a nose dive? Might need to bleed the brake and get the air out of the front lines.
ThatJeepGuy
Definitely normal on a JK to burn through the rear brakes faster than the front for a few reasons
More rear brake bias to help prevent nose dive
the ESP, traction control utilizes the rear brakes more frequently than the front
Smaller pad with a non venting rotor in the rear puts more heat into the rear brakes than the front also
I think that’s the list of reasons. But I might be missing one
zimm
40k? I've been through 3 sets of rear pads in 43k miles. They wear twice as fast as the fronts due to the electronic limited slip feature that hits the brake on the wheel with little traction to force the other tire to spin.
Gbint
It’s got everything to do with traction and skid control. Your Jeep uses rear brakes to stabilize vehicle and to slow down a spinning rear wheel in the rain you may not even notice.
black pearl
From my understanding under normal breaking conditions, it mainly uses the rears. Under fast breaking or "panic stops" it uses the fronts. Then also like said it uses the rears for stability control. I changed my rears at 36k haven't done fronts yet.
jkbarnett
Very normal for a JK to wear The rears out sooner than the front pads. It’s the way the brakes are proportioned. On my second set of rears with the fronts still good
nmwranglerx
This makes sense as to why I’m on my third pair of rear brake pads at 80K and the fronts look nearly brand new still.
Gbint
In addition, I notice that on very tight parking lot turns I can feel the rear brakes trying to compensate for outer wheel turning faster than inboard at times.
