$45k Budget build ideas?
Benito
Funny you ask this question. I did plan out my build and to do what I want to Canvas it will be about $25k
I would start with a JKUS
PR60 rear with ARB locker
PR60 fully loaded with ARB locker
1350 Driveshafts front and rear
EVO long arm kit http://www.offroadevolution.com/store/proddetail.php?prod=EVO-LONGARM-UPGRADE
EVO draglink Flip http://www.offroadevolution.com/store/proddetail.php?prod=EVO-DRAGLINKFLIP
EVO DTD front http://www.offroadevolution.com/store/proddetail.php?prod=EVO-DOUBLEDOWN-FRONT
EVO DTD Rear Lever http://www.offroadevolution.com/store/proddetail.php?prod=EVO-DOUBLEDOWN-REAR
King Bumpstops http://www.offroadevolution.com/store/proddetail.php?prod=EVO-RROCKSTOPS
EVO rear Skins http://www.offroadevolution.com/store/proddetail.php?prod=EVO-Rear-RockSkin-Corners
EVO tire Carrier http://www.offroadevolution.com/store/proddetail.php?prod=EVO-TC
ATX Slabs to match the PR60's
Nitto Trail Grapplers 37x12.3x17
Mastercraft Baja RS front seats with heated seats
OR Fab or Rock Hard Sport cage
EVO 1/4 pounder with stinger http://www.offroadevolution.com/store/proddetail.php?prod=EVO-BUMPER-FRONT, http://www.offroadevolution.com/store/proddetail.php?prod=EVO-REV-STINGER
EVO D-ring http://www.offroadevolution.com/store/proddetail.php?prod=EVO_D_Ring
Waren Powerplant
DIY Relay panel
I have chose EVO components because they are proven and tested in some of the toughest off-road environments. Since Mel runs the same equipment on EVO1 I can buy off the shelf why not out it on my rig.
R/
will
Sent from my fRuit product using WAL
A JKU is part of the 45k budget
Rccrwlr
I too was starting to wonder where some of you guys were getting parts cost. Some of these lists are over $45k in raw parts not including taxes, labor and all of the misc little bs.
OP states if labor was free
"One only needs to follow those that have been there/done that to learn how to do things proper the first time" BCH
kyle521
Way over $45k.
If you get a jk for 13 then engine swap for 15. You have about 15k for new front axle and suspension and tires. Depending on what you need for suspension it could be a pretty nice rig for 45k with a v8. If you go pr60 front and rear yes i agree it would be way over but it all depends on the specific plans for it
StrizzyChris
There's no "complete kit" from ore that is everything you need to go from stock to coilovers and driving, but they can create one for you.
Bare minimum extras that you'll need in a 4door is front lower control arms and front drive shaft.
Very recommended extras are drag link flip kit.
In a 2door you'll need a rear drive shaft as well as rear upper control arms
The "kit" includes all bracketry for the coilovers, the coilovers themselves, extended brake lines, rear track bar relocation bracket, and bump stop extensions.
Edit: probably obvious but the added control arms need to be adjustable
