I'm pretty sure you can't easily replace the map lights. The domes should be easy. What other lights are you wanting to do?
I believe I read that the maps on the rear view mirror can't be done, or at least not without some decent dissecting/electrical skills. Maybe someone will chime in with a different perspective.
Your best bet is going to Ebay for LEDs. If here is one thing China is good at, it's the LEDs lol. That's where I got mine, just try to get them form the same seller so you end up with the same tone of light. I didn't pay attention to That and I ended up with slightly different color led between front and the rear domes, it bugged me for a while but I was too lazy to order new ones, am just happy to have a lot more light inside. Also they are different size bulbs between front and rear, I believe the bulb numbers are listed in the manual. As far as the map light in the rear view mirror, I took it off but and it looks like the LED is built onto a little circuit board inside there so I just left it alone. Also the LED bulbs are cheap.
I would like to buy an LED interior light replacement package for my 2015 JKUR.
I have a set for my 2012 that work great.
Anyone have a link to purchase a package to replace all interior bulbs? Preferable an Amazon link?
I used the premium 8000k LED's from Precision LED. There's pictures in my build thread comparing them to stock. I'm sure you can find cheaper solutions. As mentioned above I. Relieve the map lights on the mirror are soldered in. I just did the domes but it made a big difference.
8000K?! Wow, that must be really blue considering "Daylight" light bulbs are already blueish at only 5000K-6500K ! https://en.wikipedia.org/wiki/Color_temperature
The 8000k are pretty damn white.
Does anyone know a good brand ledge to upgrade interior led lights including license plate there is bulb by pedals too.
I used superbrightleds.com for my JKs interior lights and tag light. I’ve also used them for lights for my WK2 as well as WJ and Maxima when I had it. Cheap as hell and they have vehicle specific layout that shows exactly what type of bulb goes where making it pretty much fool proof.
They are a good price. Are they very bright? Since I only have the two dome light bulbs in my jeep I want the most light output possible
