10% OFF CJ Destroyer Expedition Series Rear Bumper w/Tire Carrier
LōD Offroad
The CJ Destroyer Expedition Series Rear Bumper w/Tire Carrier is made out of 3/16" thick steel tube. It comes standard with 2 D-Ring mounts, tapered ends and an integrated hitch. The Xpedition Series Bumper is 58" long, a HUGE 1-1/2" hinge pin, 10 bolt points, and a pair of optional frame tie-in brackets that can be purchased separately for added strength will tie the bumper into the frame in more locations. Optional items can be added at any time. The optional frame tie-in brackets that can be purchased separately for added strength will tie the bumper into the frame in more locations. With the LoD Xpedition Series Bumper/Tire Carrier, you now can have the rear end protection you need along with the capability to carry more fuel and gear. As a result, we created several new carrier attachments from full adjustable gas cans to a universal multimounting system that allows you to attach axes, shovels, and more.
New Features Include:
-Fits 40" inch tire with no Gas can mount or 37" inch tire with gas can mounts
-Enhanced tire carrier industrial tapered roller bearing at hinge point
-Stronger high strength/ light weight military grade steel
-Fully adjustable gas can mounts
-Easier access and removal of carrier attachments
-More tire clearance
-New Universal Mount options
-Vertical Hi-Lift Jack Mount options
-Enhanced rock crawling bumper design (less catch points)
-Built-in replacement tow hitch receiver (Tow rated same as stock)
Note: Bumper is shown with upgraded attachments which are Not included in the listed base pricing. All weights are of the bumper and carrier only with no options included.
View the product here:
https://lodoffroad.com/products/cj-destroyer-expedition-series-rear-bumper-w-tire-carrier
10% OFF discount is applied at checkout.
