2012jkfng702
So here is what happens when you install a 6 inch Full Traction lift on your Rubi and your 37 inch BFG's are on back order... Not so cool looking... Damn You BFG!!! So I did the install in my buddies garage, the nice thing is my Rubi only had about 2000 miles on it so most bolts came off super easy. The Full Traction lift and instructions are easy to follow and install and any questions I had were answered by FT a phone call away. It is a tedious project, lots of little stuff that is time consuming. The only thing I suggest is that you use a lift or get the Jeep up as high off the ground as you can. It just makes it easier on yourself trying to drill holes for the new brackets. I used 6 ton jack stands and it was hard for me at 6'1" to get under there at the right angle. While I had it up I put synergy C gussets as well. I used Rancho Adjustable shocks which are amazing on this lift. I took it off road yesterday and started on setting 5. It was pretty stiff so i brought it down to 3 and it turned into a Caddi. Feel free to ask any questions and if there are any BFG reps can you please speed up the production on my tires....
