DBats
Good morning Jeep fam. I have a question I'm hoping someone can help with. This weekend I set about changing my transmission fluid in my JK with the automatic WA580 transmission, about 20k overdue for this service but better late that never! What I've discovered through looking up various videos and forums is that there isn't a whole lot of write-ups specifically for the WA580 as most folks doing fluid changes themselves are doing them on the 42RLE.
So I dropped the pan, drained the fluid and measured. I only managed to get out about 2.5 quarts which I thought was low. Buttoned the jeep back up and put back in exactly what I'd taken out, 2.5 quarts. Checked the dipstick and couldn't see any red fluid on it whatsoever so I added the rest of the 3rd quart and was finally able to see a smidge of red on the tip of the dipstick. Reading a previous post on this forum about how most folks would add up to 4 quarts at first and then check the fluid level to top it off I decided to pour a 4th quart in there myself.
Started the jeep, cycled through the gears a few times, left it in neutral and checked the fluid with the engine idling. I couldn't get any fluid to read on the dipstick at all even after adding nearly double what I had drained out. So I let the jeep sit overnight allowing the fluid to settle and I could get a better read in the morning. The following day I go out to check the jeep after letting it sit all night and checking the jeep COLD, the durpstick reads well over the two bottom cold holes and is halfway up the dispstick to the top hot holes. This made me believe I had overfilled the transmission but I started it up, cycled the gears again, let it idle in neutral and checked the fluid, now the fluid showed BELOW the bottom cold hole...
At this point I'm very confused, but I took it for a drive to see if I could get the transmission into better operating temp to see if the fluid level would go up or down. After 45 mins of running errands I get back home, check the fluid level and it's just above the bottom COLD hole. I have no idea at this point, all I want to know is if I put too much in or too little lol...
Attached is an artist rendering of what my levels look like: The first image is my fluid level with the jeep COLD, and the second image is the fluid level with the jeep HOT having been driven for 45 mins.
Also I should note that while driving I didn't experience any shifting problems or abnormalities it was smooth and drove fine.
Anyone have any pointers on what I should be or shouldn't be doing? Thanks in advance!
