Boots or no boots on rancho 9Ks
2nd.gunman
I'm running the 331 front rancho 9K shocks and the boots never stay in place properly so I'm think of just taking them off and running without them. Anyone running this way? Worried about damage to the shaft.
When I fitted them I clipped the top in on the washer and just let the bottom sit on the top of the shock body, didn't fit the zip tie so I could clean them out every now and then but they've slowly been working themselves down the body and have popped off the top washer. See the photos
2nd.gunman
I wasn't going to put them on at first but was a bit afraid of damage to the Teflon coating on the shaft. I'm can't believe they won't stay on properly though
No boots. As mentioned, they just trap in dirt and water and will cause the shaft to rust.
JeepJeep75
I was wondering this as well. I just installed 9K's all around. The rear boots are hard plastic, that are not attached at all on the bottom. The fronts are floppy silicone that don't stay put no matter what. I'm cutting them off. Thanks guys!
BenJKWrangler15
Not sarcastic. The answer is I've never seen anyone touch the shroud on the stock shocks, but I had to type 10 characters, so, thus the dots.
Sounds good, thanks! Yeaaah, that minimum characters requirement can be a real PITA sometimes 🙃 But I guess it's there for a reason
MacRubi2
This question was answered almost 50 years ago
That's hilarious....I have that album🤘
Ok so most if not all say no boots so why do the shocks still come with them if they don't serve a purpose 🤔
I get the idea that dirt and water can be trapped in the boot causing issues but I'm still running mine on all four corners....I like the look😎
That's hilarious....I have that album落
Ok so most if not all say no boots so why do the shocks still come with them if they don't serve a purpose 樂
I get the idea that dirt and water can be trapped in the boot causing issues but I'm still running mine on all four corners....I like the look
The boot is designed to keep dirt and crap out so the piston shaft of the shock doesn't get scratched as it moves up and down inside the seal eventually causing wear and leakage. HOWEVER, if dirt/mud gets trapped inside the boot (which commonly happens), then you have just made the problem worse because it doesn't come out. I've always ran boots on shocks up until a few months ago. One of my zip ties on the boot was loose but the boot was still on the shock body. Just for kicks I pulled the boot off and peeked inside and it was nasty inside. I decided to cut it off, turns out all four shock boots were the same. I've known enough guys over the years that run without them without a problem, so mine are staying off for now, I can clean them off with a pressure washer if needed.
